Original owner since '86 planning updates...
zxr250cc
Re: Original owner since '86 planning updates...
Post by zxr250cc » Tue Jul 03, 2018 3:58 pm
I have been looking at the G2 kit for the 2.3 motor for a quite while and wonder if it is a good replacement for the broken BCS? The price is certainly reasonable, it seems. I think others in here have used this? Happy with it?
1999 Taurus SE 24v DOHC Spruce Green
2004 SVT ZX5 Focus EAP Screaming Yellow
DAReese
Post by DAReese » Tue Jul 03, 2018 6:57 pm
zxr250cc wrote:
Mon Jul 02, 2018 12:22 pm
Thanks for the quick reply. I will order a spare set, I guess, as they are certainly not a normal stock item in any parts houses.
I tried to get the dash panel out but could not get the speedo cable loose. Are bulbs like the clock on the back of the dash panel? Or does it have 168 or 194 bulbs?
Oh, I have tags for the car now and can drive it around now! It can be driven as if it is a normal daily driver car now, if needed.
The lights are on the back of the instrument panel, but they are not the same bulbs as the clock. Some have soldered 194s in the holder to replace them, but they aren't 194 bulbs. Image
To get the dash out, you need to reach behind it and squeeze the white clamp ring that holds the speedometer cable in the speedometer.
MarkM
Post by MarkM » Tue Jul 03, 2018 9:37 pm
The lights are on the back of the instrument panel, but they are not the same bulbs as the clock. Some have soldered 194s in the holder to replace them, but they aren't 194 bulbs. http://merkurmidwest.com/catalog/i174.html
Your link won't display as an image. Here's a shot of the bulb from that page.
Mark
Post by merkurdriver » Wed Jul 04, 2018 12:52 am
G2 Gillis valve is an excellent unit for an excellent price. Be sure to get the XR4Ti specific "kit" and not just the "universal" one.
zxr250cc
Post by zxr250cc » Wed Jul 04, 2018 9:08 am
Great info, thanks for the help.
I am guessing that the bulb might be a PC168 which is a 168 bulb in a small socket that can plug in and rotate 1/4 turn to fit its' holder? Ford and Chrysler both used them. I am making this guess without being at the car, as it is 250 miles away. Standard Motor Parts have the socket itself for sale but Phillips sell the socket with bulb in it already as a PC168. ???
I will get a G2 XR4Ti kit as a replacement for the BCS. One more item on the parts list!
I know what infinity means when I am asked; it is the length of the list for things I want to buy for this old car! haha
zxr250cc
Post by zxr250cc » Fri Jul 06, 2018 5:50 pm
Hi all,
I have compiled a list of bulbs for the XR4Ti as an exercise in looking up stuff. I mentioned I'm in the auto parts business, I think. What I am wondering about is the PC168 bulbs I meant to try last weekend when I could not get the speedometer cable loose. I seem to remember a list like this in here in the past and this may be boring or redundant.
XR4Ti bulb list for interior and exterior bulbs
37 Dash lights, ashtray light
89 Dome light, trunk light
904/912/921 Parking lights, any will work, different intensity levels
1156 Under hood bulb, rear turn signal, back up light
1157 Tail light, stop light
168 Side marker, map light (instrument panel light?)
194 Glove box light, map light (instrument panel light?)
9004 Headlight
880 Fog light, rated 27 watts power consumption
893 Alternate fog light bulb? identical shape, 37.5 watts power consumption, anyone used these?
912/921 High mount brake light, either works, different intensity level
1816 License plate light
LED bulbs may be substituted for many of these numbers. Some flasher units will not work with LED bulbs and would
need to be changed out for a compatible unit.
HP-4100 Bulb socket for INSTRUMENT PANEL BULBS, Standard Motor Parts, use either 168 or 194 bulb
168PC Bulb socket with 168 bulb installed fits in instrument panel ??? Yes? No???
I see 2721 (Sylvania) bulbs listed for the UK Sierra and that crosses to a 74 bulb it seems. Anyone used either one for the dash? I see no cross for the small socket mounted bulbs for the clock.
