87-89 Brake MC Kit
Andy82GT
87-89 Brake MC Kit
Post by Andy82GT » Sat May 05, 2018 11:06 am
My front brakes are seizing up, already replaced both calipers. Already purchased a used Master Cylinder, but would rather rebuild than go through the trouble of install and it being bad also, but Raybestos MK1717 kit is nowhere to be found? Have any of you found this or suitable seal kit?
Assist most appreciated!
82 Mustang GT, 408W install in prog
83 Ranger, 302, T5
85 XR4TI, need to do AT>T5 swap! Arrgh!
Re: 87-89 Brake MC Kit
Post by Mike McCreight » Sat May 05, 2018 4:59 pm
Post by thesameguy » Sat May 05, 2018 9:37 pm
Are you sure is isn't the flexible hoses between body and caliper? They can swell closed internally preventing the piston from properly retracting.
Post by Mike McCreight » Sun May 06, 2018 6:46 am
X2.
Typically happens on one side though.
On that MC kit, it says 85-89. I have no direct experience with it, the MC are different from mid-86 on.
Andy82GT
Post by Andy82GT » Sun May 06, 2018 4:25 pm
Yep, early MC is different. Plenty of parts for those, go figure.
Got braided lines, wonder if those can collapse, and on both sides?
Gonna go ahead and pull MC and check it out...thanks for replies, will update.
83 Ranger, 302, T5
Post by thesameguy » Sun May 06, 2018 7:26 pm
Braided lines will prevent the rubber from ballooing out, but typically won't stop them from collapsing in. I do agree that it'd be unusual to see the same effect on both sides, but in that sense we're talking about a street-driven car that's getting routine maintenance. If the car sat for a while, anything is possible. Some history there would help for sure... because I don't ever think I've even heard of a master cylinder trapping pressure... that's just as weird. :)
zxr250cc
Post by zxr250cc » Fri Jun 01, 2018 10:47 am
1999 Taurus SE 24v DOHC Spruce Green
2004 SVT ZX5 Focus EAP Screaming Yellow
Andy82GT
Post by Andy82GT » Tue Jul 17, 2018 6:23 pm
Well, even though I cannot find the elusive rebuild kit for these (Raybestos MK1717), I went ahead and pulled the MC to check it out, removed lock ring and washer, but the piston won't come out!!!
What's the secret???
83 Ranger, 302, T5
zxr250cc
Post by zxr250cc » Tue Jul 17, 2018 7:19 pm
I notice that the Bumper to Bumper parts warehouse in Monroe, LA has a remanufactured MC for sale. It is a good way to solve the non available MC kit problem as it is already rebuilt. Just a thought.
Andy82GT
Post by Andy82GT » Sat Aug 25, 2018 5:48 pm
Thanks zxr250cc for the tip... Soooo...
I got that remanufactured Master Cylinder from Bumper2Bumper, removed fuel lines and vacuum lines for access, bench bled and installed MC, bled all 4 corners, and now the pedal goes to the floor! Checked all fittings, no leaks. Re-did entire bleeding process, still no good... looks like I got a faulty master! @#$%&!!!!!!
Why are these so hard to come by? It almost seems I will have to revert back to 85 MC and booster!
Does ANYONE know where I can get a new MC or a rebuild kit for an 87-89? Or a David Godfrey T-bird adapter? Or any other options?
Any assist most appreciated, bros!
83 Ranger, 302, T5
jkxr4ti
Post by jkxr4ti » Thu Aug 30, 2018 8:01 pm
I may still have an extra DG master cylinder kit. Let me check and get back to you.
Post by my8950 » Fri Aug 31, 2018 9:01 am
Check into the Scorpio MC/Booster conversion...
zxr250cc
Post by zxr250cc » Fri Aug 31, 2018 9:10 am
Hi all,
It is possible that another rebuilt one might be available. I will know later today.
zxr250cc
Post by zxr250cc » Fri Aug 31, 2018 11:08 am
Hi all,
I think I found one in Philadelphia and will be able to let you know in a few days as the holiday coming up slows down shipping of items. I have arranged to have it shipped to Tulsa. (If it truly exists and I don't have a call back saying it really wasn't there.) Let's all cross our fingers for good luck! I am not a vendor in here and only trying to facilitate getting a hard to find part.
dunhamr1
Post by dunhamr1 » Fri Aug 31, 2018 11:35 am
Hi all,
Found a kit supplier? Or found a place that rebuilds master cylinders?
-Ryan Dunham
Daily: 2016 VW Golf R
