Accidentally shortened Steering Shaft - Bearing Installation Tips
Re: Accidentally shortened Steering Shaft
Post by John Brennan » Tue May 08, 2018 4:49 pm
Excellent-- made your own slide hammer, I see. 8)
Post by DPDISXR4Ti » Wed May 09, 2018 8:01 am
Sorta, kinda. At first it was the vise-grip that was only sliding as I wacked it with the hammer. Then I bit down a little harder with it and gave it another go. This time the shaft moved. Yea!!!
Post by John Brennan » Wed May 09, 2018 8:42 am
So, do you have it back together? As Bob Dylan would say, "How does it feeeel?"
Post by DPDISXR4Ti » Wed May 09, 2018 9:48 am
Got it all back together last night, only to find that the battery was dead. Not sure if it's dead-dead or just in need of re-charge. Left it on the charger overnight.
Post by John Brennan » Wed May 09, 2018 10:20 am
"It's only mostly dead..."
Post by my8950 » Wed May 09, 2018 1:22 pm
I really want to do the scorpio steering column swap on mine, along with this bearing.
Post by DPDISXR4Ti » Fri May 11, 2018 8:33 am
Had I known about the bearing at the time, I certainly would have done it while the car was gutted (which clearly was the time to do the Scorpio steering column swap). But it's not that tough to do just the bearing install on a fully outfitted car. I have a spare steering shaft that perhaps I'll bring to Carlisle along with another batch of bearings. I drove the car with the bearing installed for the first time last night. It's an awesome upgrade, even more so if you're running manual steering.
Post by DPDISXR4Ti » Thu Jan 10, 2019 12:33 pm
Just had a question about the after-market steering bearing myself and others have sold not being mounted quite level with the housing. In short, it's not an issue since it's a mild-interference fit and will shift if needed on it's own. If you want to level it up prior to install, just tap around the perimeter of the bearing to level it up with the housing. Just be sure not to hit the seal as you can damage the bearing that way.
Post by my8950 » Thu Jan 10, 2019 2:29 pm
Thank you!
twin turbo
Post by twin turbo » Fri Jan 11, 2019 4:17 am
This is a good upgrade. it was original on Group A cars with similar bearing. But not "collapse" colum om them either, since Are only a straight shaft on them
Post by andyofcolumbusmerkur » Fri Jan 11, 2019 6:22 pm
I have a loose scorpio column around here someplace. Make me an offer. Or maybe trade for some xr goodies.
reddy2300
Re: Accidentally shortened Steering Shaft - Bearing Installation Tips
Post by reddy2300 » Fri Jan 11, 2019 6:52 pm
Great. Another mod. What's the advantage of the Scorpio column?
1987 5-speed XR4ti-70K mile "barn find", Rosso Red, Grant wheel, short throw shifter, PE/big VAM, 255lph pump, 3" Stinger/Magnaflow exhaust, MD "shorty" radiator/IC, fake BBS wheels, Koni Yellows, Rapido sway bars, poly/aluminum bushes, Gillis valve, Eurolights,
Post by my8950 » Fri Jan 11, 2019 7:16 pm
Says Columbus, but where are you located? Or PM me and we can do details....
Post by andyofcolumbusmerkur » Sat Jan 12, 2019 9:59 am
Scorpio column has adjust lever.
Post by andyofcolumbusmerkur » Sat Jan 12, 2019 10:01 am
email: a_5432@yahoo.com
cell: 234-738-5495
I will delete all this in a day or so. I hate robots calling and texting me.
