Harmonic balance bolt
Larry H
Post by Larry H »
What is the trick to remove the harmonic balance bolt. Mine is real stubborn on my 89 XR!!!
Is there a tool you can borrow from Oreilly, Autozone, etc....
thanks
Larry with Five XR4s and Two Scorpios
Re: Harmonic balance bolt
Post by hEaT »
Won't turn?
Throw the car in 5th and put the ebrake on/have someone stand on the brakes. Never had trouble with the bolt with a good 1/2 ratchet or breaker bar. The pulley can be a huge PITA and need a puller (will have to remove the fans at a minimum to get one in there).
If the bolt is that stuck, likely the pulley will be too. If you can't get the bolt loose with a breaker bar, either look into bumping the motor with the breaker bar handle on the ground or get an impact in there.
Larry H
Post by Larry H »
Thanks Joe for the input. However, the car is a C-3 not the T-9. Ford had to have a tool for the removal of the balance!
Didn't need the tool to remove the pulley on my C3. Came off with some light levering and tapping.
If that doesn't work, Jeff Herson at MPM might have the tool (not to buy but borrow).
Post by my8950 »
13/16" socket and a breaker bar.
I used an impact on mine also....
I am also looking for a better way to remove the pulley.
Post by hEaT »
Larry H wrote: Sun Jun 24, 2018 11:02 am Thanks Joe for the input. However, the car is a C-3 not the T-9. Ford had to have a tool for the removal of the balance!
I can't imagine the techs doing this...but remove the coil wire, place socket on with breaker bar, press breaker bar against the floor...bump starer.
To remove the bolt:
I used a pipe wrench to grip the center shaft housing of the pulley--where the bolt slides into--and a socket on a breaker bar on the bolt.
For better leverage on the pipe wrench I slid a length of 1-1/2"/2" diameter galvanized pipe over the handle.
Then I rotated the crank pulley with the pipe wrench on its center shaft so it the end of the pipe wrench levered snug against the floor.
Then using the socket with breaker bar you can muscle the bolt loose.
This works. It takes a bit of jiggling to get the pipe wrench in the right position, but nothing more.
For one job, I used this Big Boy pipe wrench from the local tool rental shop (~9$). I used this one to hold on to the pulley edges (covered with couple layers of duct tape).
cmouta
Post by cmouta »
I've used a "locking chain clamp" from harbor freight with a junk serpentine belt around the pulley for grip and a helper with a breaker bar + floor jack bar for additional leverage.
Chris
hEaT wrote: Sun Jun 24, 2018 3:10 pm I can't imagine the techs doing this...but remove the coil wire, place socket on with breaker bar, press breaker bar against the floor...bump starer.
Both times I "bumped the starter method" :)
Scroll up: the OP asked about removing the bolt on his C3.
Post by hEaT »
Ed Lijewski wrote: Mon Jun 25, 2018 9:23 pm Scroll up: the OP asked about removing the bolt on his C3.
That won't work with the C3 in park?...
hEaT wrote: Mon Jun 25, 2018 10:13 pm
Of course it will. Turn the key, the starter engages, the crankshaft rotates exactly the same, regardless of transmission type (as long as it's in N/P).
Post by hEaT »
John Brennan wrote: Mon Jun 25, 2018 10:36 pm
Thanks - That's what I thought and was confused by Ed's response.
