LF: Parts vendors in here please.
Matt01
Post by Matt01 » Mon Jun 25, 2018 8:52 pm
Looking for a few items.
Dipstick tube + dipstick (new if possible, good used is fine) (1989)
Starter Y bracket
Re: LF: Parts vendors in here please.
Post by Mike McCreight » Tue Jun 26, 2018 10:51 pm
Pretty darn sure I have that here, Matt.
Rocky's Wrench
Post by Rocky's Wrench » Wed Jun 27, 2018 12:56 am
Do you realize that the "Y" brace is just a NVH item?? It's not required. The '71 to '74 EAO2.0L Capris had
a similar brace, they really don't do anything...
SteveL
Orphan Addict...
Matt01
Post by Matt01 » Wed Jun 27, 2018 6:14 am
PMed you Mike. Might be a good time to meet up.
Post by hEaT » Wed Jun 27, 2018 9:22 am
This. I think I threw one out a few weeks ago, same with the brace on the driver's side.
Joe
1985 Nimbus Grey XR
2017 Ford Focus RS
Post by Ed Lijewski » Wed Jun 27, 2018 9:49 am
Each of you have NVH Engineering degrees hanging on your walls?
Post by John Brennan » Wed Jun 27, 2018 10:19 am
Dead nuts on. Not only does it help with NVH, which you may or may not care about, but it structurally stiffens and strengthens the drivetrain at that point. How can that not be a Good Thing?
Post by Ed Lijewski » Wed Jun 27, 2018 10:43 am
Here's a personally oft observed datum re NVH: my XR, with the starter Y brace, and with a/c compressor compressing is quite distinctly smoother running at low and low mid speeds (where my driving mostly operates). It's palpable.
Grayson
Post by Grayson » Wed Jun 27, 2018 1:47 pm
My favorite quote that I've heard with regard to certain brackets is "Ford is so cheap, that bracket really has to be there for a good reason." I can't shoot holes in that argument.
Post by Ed Lijewski » Wed Jun 27, 2018 1:55 pm
Yet internet injuneers will still say why, why, Y, Y...?
Post by hEaT » Wed Jun 27, 2018 2:05 pm
Did the Ranger or other cars with a mini starter also use that bracket? Curious if it was necessitated by the very large and heavy factory starter, or truly was a performance part/NVH part separate from the starter itself.
Joe
1985 Nimbus Grey XR
2017 Ford Focus RS
Rocky's Wrench
Post by Rocky's Wrench » Sat Jun 30, 2018 11:57 pm
Well Ed, you're still an opinionated idiot, you see, I've been racing and beating EAO2.0Ls and Lima 2.3Ls for the better
part of 40 years. Can you guess how many problems I've seen because I've saved 19oz from leaving those braces off??
And to answer your next question, yes, 19oz is enough of a weight saving to scrap those pieces of afterthought. You
couldn't possibly understand the lengths racers will go to to save over a pound of weight.
So go ahead and keep your NVH braces, I wasn't aware you had an XR, so you must be the eggspurt, you do what you
think is best...
SteveL
Orphan Addict...
Post by Ed Lijewski » Sun Jul 01, 2018 7:47 am
As I always note, YMMV.
For we who appreciate a quiet(er) cabin, tossing something engineered to address some part of NVH considerations is a zero sum game...no tangible benefit.
We don't race. Probably never, or at best seldom, see the tach at red lines.
Note that the OP asked only where to find the Y brace; nothing more.
Instead of advice that categorically (Categorically!) says toss it-from two members who each responded from their experiences in racing and most likely don't DD those cars, inquiring of the OP how s/he uses the car would've been appropriate. My input cited alternative considerations to racing approaches to balance the one-sided ("opinionated") info they provided.
Rocky's Wrench
Post by Rocky's Wrench » Sun Jul 01, 2018 8:23 pm
Actually Ed, I seriously doubt you'd be able to tell whether the brace was installed or not. Now if you have poly engine mounts,
you still wouldn't be able to tell, but the NVH will increase because of the mounts, not because the braces are missing...
SteveL
Orphan Addict...
Post by hEaT » Sun Jul 01, 2018 9:09 pm
This is why I didn't mind ditching those braces. ChuckW mounts, poly trans mount. No bit of rubber in the suspension besides the tires. I don't think I'd notice the NVH change with the brace in place.
Joe
1985 Nimbus Grey XR
2017 Ford Focus RS
