Tach reads about 50%
JimG
Post by JimG » Wed Jul 25, 2018 4:40 pm
Tach started reading about 50% of what it should ie: 500 when should be 900-1000 and 2000 when sb 4000. Any thoughts ? How can I test the guage? Could it be the ignition module?
Jim Gosses
DAReese
Re: Tach reads about 50%
Post by DAReese » Wed Jul 25, 2018 5:06 pm
Most likely it needs re-soldered.
cmouta
Post by cmouta » Thu Jul 26, 2018 8:34 am
Yes, definitely resolder the board inside and it helps to use a really good, hot soldering iron.
See here:
http://forum.merkurclub.com/forum/viewt ... c&start=42
and here:
http://forum.merkurclub.com/forum/viewtopic.php?t=10560
Chris
2013 Nero Fiat 500C Abarth
1974 VW Thing
JimG
Post by JimG » Fri Aug 03, 2018 3:26 pm
Resolderered the board - now worse! Anyone have good tach that they want to sell? Am also considering aftermarket
Jim Gosses
Post by my8950 » Mon Aug 06, 2018 2:35 pm
Take it back apart and try to clean the potentiometer contacts.
Mark the current location and turn it a touch back and forth.
Also try some contact cleaner on it.
