Euro/Horn Turn-Signal Switch Conversion
itking
Post by itking »
I have successfully converted the Europe turn-signal switch to a turn signal switch to a switch with cruise control.
Here's some pictures & comment of what I did.
Ron
1989 Merkur XR4Ti - Magenta [My XR]
1988 Merkur XR4Ti - Bunny [Wife's XR]
1988 Merkur XR4Ti - Raven [Daughter's XR]
1985 Merkur XR4Ti - Wombat [Youngest Son's XR]
1997 Dodge Ram 1500 4x4 5.9L - Betsy
2002 Buick Century Custom - Daily Driver
1968 Dodge Charger 383
itking
Re: Euro/Horn Turn-Signal Switch Conversion
Post by itking »
First it took apart the broken switch with cruise cause I needed the pin with the tab.
Note. You will have to drill out the rivits carefully.There are 2 other pins that each have tabs which can be used to make the same pin/tab combo. So 1 broken cruise switch can be used to modify 3 euro's.
Ron
itking
Post by itking »
You will have to remove the wire with a solder gun. Carefully use a Dremel to cut the bent metal piece out of the way in the channel the wire will follow up to & to also make a indentation so the tab will be flush with the plastic.
Ron
itking
Post by itking »
The solder wire to tab, carefully press pin in place while guiding the wire in the channel.
Ron
itking
Post by itking »
Waalaa! It works. The hazard switch is shorter, but that works.
Ron
itking
Post by itking »
I just have to put a "SET/RES" decal over the printed on horn decal.
Ron
Nice work! :cheers
Outstanding post-- thanks! :notworthy
Nice, someone is going to get rich doing this!!!
Good thinking though here... :)
