Euro/Horn Turn-Signal Switch Conversion
I have successfully converted the Europe turn-signal switch to a turn signal switch to a switch with cruise control.
Here's some pictures & comment of what I did.
- Attachments
- 3switches.jpg (28.68 KiB) Viewed 6659 times
Ron
1968 Dodge Charger 383
Re: Euro/Horn Turn-Signal Switch Conversion
First it took apart the broken switch with cruise cause I needed the pin with the tab.
Note. You will have to drill out the rivits carefully.There are 2 other pins that each have tabs which can be used to make the same pin/tab combo. So 1 broken cruise switch can be used to modify 3 euro's.
- Attachments
- BrokenSwitchTakenApart.jpg (27.12 KiB) Viewed 6658 times
Ron
You will have to remove the wire with a solder gun. Carefully use a Dremel to cut the bent metal piece out of the way in the channel the wire will follow up to & to also make a indentation so the tab will be flush with the plastic.
- Attachments
- WireRemoved.jpg (47.23 KiB) Viewed 6657 times
- EuroSwitch.jpg (42.3 KiB) Viewed 6657 times
Ron
The solder wire to tab, carefully press pin in place while guiding the wire in the channel.
- Attachments
- ModifiedEuroSwitchDetail.jpg (42.3 KiB) Viewed 6657 times
Ron
Waalaa! It works. The hazard switch is shorter, but that works.
- Attachments
- ModifiedEuroSwitch.jpg (122.31 KiB) Viewed 6657 times
Ron
I just have to put a "SET/RES" decal over the printed on horn decal.
- Attachments
- Decal.jpg (86.18 KiB) Viewed 6657 times
Ron
- merkurdriver
Outstanding post-- thanks!
Nice, someone is going to get rich doing this!!!
Good thinking though here...
