Anyone DD theirs?
Rocky's Wrench
Re: Anyone DD theirs?
Post by Rocky's Wrench » Fri Nov 02, 2018 10:38 pm
John Brennan wrote:
Mon Sep 10, 2018 3:59 pm
The only grounds I've added have been taillight matrices-to-body ground-- they pop up as an issue in lots of these cars. I would do it to any XR I own. The rest were matters of repair and maintenance, at least for me.
Part of the problem is the wire gauge used in the stock configuration isn't adequate for all the bulbs... So what happens when you have
too many amps for the wire??
SteveL
Orphan Addict...
Rocky's Wrench
Post by Rocky's Wrench » Fri Nov 02, 2018 10:46 pm
Yes, I daily drive mine, which I got 6 months ago. After it sat in a field for 4 years. The day I bought it, we
stuck a battery in it, fired it up on 4+year old gas, and drove it around the block. Two weeks later, after a
new timing belt, an oil change, fresh coolant, and an accessory belt, It attended the 2018 Olympus Rally.
I've daily driving it since then...
SteveL
Orphan Addict...
Post by John Brennan » Sat Nov 03, 2018 8:12 am
Well, if something's going to happen, years and years later, I'm still waiting on it. Nothing ever has. What do you suggest?
Rocky's Wrench
Post by Rocky's Wrench » Sat Nov 03, 2018 12:14 pm
You've already taken care of the problem, by adding the ground...
SteveL
Orphan Addict...
Post by John Brennan » Sat Nov 03, 2018 3:08 pm
Ah, got it! I misunderstood!🍻
eaton53
Post by eaton53 » Sat Nov 03, 2018 3:51 pm
As of 10am today mine's in storage until the end of March, so obviously not.
There's a chance of a wintry mix at the end of next week, so it's put away just in time.
Car show season starts at the end of April, so come on Springtime!
'89 XR4Ti
Post by Ed Lijewski » Sat Nov 03, 2018 6:25 pm
The weaker and more common failure prone section(s) is inside the harness connector.
trueblue1968
Post by trueblue1968 » Thu Jan 03, 2019 3:43 pm
once upon a time.....
Next iteration Not so much.... :twisted:
TOO MUCH IS NEVER ENOUGH!........
....More to come :twisted:
Post by John Brennan » Thu Jan 03, 2019 4:30 pm
That happened to me in 50% of the XR's I had for a long time. The ground issue, 100% (won't count the one I got new and only had for seven years). I don't know what qualifies it as weaker, or more common. :dunno
Absolutely worth checking 100% of the time, nevertheless. :cheers
Post by Ed Lijewski » Thu Jan 03, 2019 6:49 pm
The female spring connectors weaken over time. The male prongs accrete crud. Bulb contacts lose solder and grip.
Each and all are weaker and common failure prone points.
