How did you intercool
markwemple
Post by markwemple » Mon Sep 10, 2018 7:28 pm
I know there are several good kits but did anyone do their own set up? There is a guy on youtube who used a saab 9000 intercooler and mounted it low, just behind the lower bumper air intake.
Re: How did you intercool
Post by merkurdriver » Tue Sep 11, 2018 12:51 am
I'm going to have a super biased opinion here but I like the Merkur Depot set up best
www.merkurdepot.com
My black car in the pictures has had nearly 10 different intercoolers on it over the last 15 years...
From home brew set-ups using (used) Audi and Volvo intercoolers, to the Rapido intercooler kit specifically for the XR4Ti, all the way up to the previous set up that used a fairly Forge RS500 intercooler. Finally settled on the same set up we currently offer.
This intercooler set up has proven to flow better, have less pressure drop, and cool better than anything else that has been on my car.
(Air conditioning has to go to fit it in there FYI, so if you need A/C then scratch this one.)
LITTELHAWK
Post by LITTELHAWK » Tue Sep 11, 2018 2:03 am
www.merkurdepot.com
I have this setup in mine. A/C is still in there too, for now. I just ran my intercooler to throttle body pipe in the clearance above the fan and up.
P_20180911_005733_vHDR_Auto (2).jpg (1.38 MiB) Viewed 3024 times
dunhamr1
Post by dunhamr1 » Tue Sep 11, 2018 11:12 am
For Simplicity and ease of installation, I would definitely go with the Merkur Depot kit while he's still got some in stock! He's also got a piping kit to go with it, no need to muck about if you don't need/want to.
I personally am (going to be) using a Cosworth 2WD intercooler paired with a shorter radiator (I used one from a Saab 900). This requires some fabrication of a mount to hold the radiator since it doesn't have "Wings" like the correct Cosworth one would, though the intercooler bolts right in. I'm now designing/looking for piping solutions which will also involve installing a rotated upper intake (and associated wiring length increases), moving the alternator to the passenger side, and clocking the compressor on the turbo. The intercooler and radiator are mounted in the car but I haven't plumbed the intercooler to date.
-Ryan Dunham
Daily: 2016 VW Golf R "Matti"
Ersatz36
Post by Ersatz36 » Tue Sep 11, 2018 1:35 pm
My car has an older version of the Merkur Depot setup on it, it has a short radiator with an IC mounted above the radiator similar to the European cars, it's packaged pretty neatly so it doesn't go anywhere near the condensor for the AC.
DAReese
Post by DAReese » Tue Sep 11, 2018 2:38 pm
Merkur Engine Bay 3.jpg (376.61 KiB) Viewed 4337 times
Merkur Engine Bay 2.jpg (395.67 KiB) Viewed 4337 times
Merkur Engine Bay 1.jpg (342.34 KiB) Viewed 4337 times
ImagePlanakis custom intercooler and radiator. I've got a small leak in the radiator now, so depending upon how easy it is to fix, I might be looking for a different setup. I do have Mike's shorty radiator which if I measured correctly, should work with the intercooler.
DAReese
Post by DAReese » Tue Sep 11, 2018 2:55 pm
With Essie valve cover and catch can
(1.9 MiB) Not downloaded yet
Post by my8950 » Fri Sep 14, 2018 9:23 am
Good information here...
I am wondering, are you guys also putting the intake air temp sensor in the intake line somewhere?
I've got my intake manifold off now to clean, thinking I may also install a boss to measure intake air temp as well.
markwemple
Post by markwemple » Fri Sep 14, 2018 11:00 am
Preference for cross flow, return flow, or no real difference?
Post by Esteban » Sun Sep 16, 2018 4:05 am
For a standalone, always put the IAT in cold side piping cause sensor heatsoaking will cause startup issues. I'd put it in the same place even if you were just monitoring it too
Post by Esteban » Sun Sep 16, 2018 4:22 am
IMO, Knowing your goals is needed for intercooler selection. What horsepower goals, what turbo, and how much PSI? Do you need to keep A/C? Do you care about throttle response? Planning on a rotated intake or larger throttle body?
There are cheap cores out there that seem like a good deal but they don't flow as well as the good stuff and cause a larger pressure drop.
A tip about intercooler piping: Try to avoid tight and sharp bends and using many reducer couplers. Hot side piping doesn't need to be any larger than the turbo outlet, and cold side piping also doesn't need to be any larger than the throttle body either.
markwemple
Post by markwemple » Sun Sep 16, 2018 10:20 am
There's a guy on line that is selling a kit that locates the intercooler to the battery box. He says there is a lot of air flow there. Doesn't make logical sense to me.
Post by andyofcolumbusmerkur » Sun Sep 16, 2018 1:05 pm
Never seen an intercooler mounted in the battery box before. Anyone have a pic of fmic setup with piping in reverse? Turbo>drivers side inlet>passengers side outlet>throttle body? Preferably an npr fmic. Thanks.
Post by John Brennan » Sun Sep 16, 2018 1:20 pm
Battery box has good airflow, has been measured by people who know what they are doing. Search MCAF and www.turboford.org.
www.merkurtech.com has lots and lots of pix of setups in Picture Pages. Sort by "Intercoolers."
Post by andyofcolumbusmerkur » Sun Sep 16, 2018 1:21 pm
My fave style would be air into the front, out the hood. Subaru WRC style. Remember it's high pressure under the car and low pressure above. Like an airplane wing. So wrx/svo type is working against this principle.
