Best Front Brake Setup for 14-inch Wheels?
patentgeek
Post by patentgeek » Sat Nov 03, 2018 8:48 pm
Per the post linked below, I'm installing XR4Ti spindles as part of a coil-over + rack-and-pinion conversion on a 1966 Ford Cortina Mk1 GT.
viewtopic.php?f=30&t=33880
I've read through numerous posts on this forum about front brake upgrades, but it's not always clear as to which of those care compatible with the 14-inch wheels on my Cortina. The Cortina weighs less than 2000lbs, or about 1000lbs less than an XR4Ti, so stock XR4Ti brakes would be fine - - - but I'd like to see what other front brake options are out there.
Re: Best Front Brake Setup for 14-inch Wheels?
Post by merkurdriver » Sun Nov 04, 2018 1:07 am
www.merkurdepot.com big front brake kit will clear (most) 15" wheels, but not 14".
Stock XR4Ti front brakes might be your best bet and indeed and upgrade for such a small car.
Post by John Brennan » Sun Nov 04, 2018 10:46 am
I have a set I'm not using if you want them. Just need rotors and pads. Mintex and EBC make good pads for these brakes.
Post by my8950 » Sun Nov 04, 2018 7:14 pm
And the fact that many people are removing the stock XR brakes and putting them in the bin will make them cheap.
Post by Mike McCreight » Tue Nov 06, 2018 8:22 am
Drop me a line for some Greenstuf pads.
Post by John Brennan » Tue Nov 06, 2018 10:32 am
I've used those to good effect. :thumb Their rotors are nice, too, if still available, and if they fit your car.
reddy2300
Post by reddy2300 » Tue Nov 06, 2018 6:19 pm
As the guys said, stock XR rotors with Greenstuff pads worked pretty well on my XR for a long time. Would be better on your lil Capri.
Not sure where you're located but, I have a complete front brake setup with vented rotors and "unknown" pads. Almost new. Came off a rolled-over car I bought. I have the knuckles too, if you don't' have those yet. Dirt cheap. Shipping might kill it, though.
1987 5-speed XR4ti-70K mile "barn find", Rosso Red, Grant wheel, short throw shifter, PE/big VAM, 255lph pump, 3" Stinger/Magnaflow exhaust, MD "shorty" radiator/IC, fake BBS wheels, Koni Yellows, Rapido sway bars, poly/aluminum bushes, Gillis valve,
Post by hEaT » Fri Nov 23, 2018 3:37 pm
If you have some cash to spend, reach out to the guys at TCE:
http://www.tceperformanceproducts.com/
Todd has the measurements for the stock XR knuckle and can make a custom adapter for any Wilwood caliper you want. You could work with him to find a setup that works with you wheels, and will be much better than the OEM XR stuff.
