Is there a quick fix for the Lower Radiator Hose?
oemoilleaks
Post by oemoilleaks » Fri Dec 07, 2018 3:02 pm
I'm finally getting around to tackling some major maintenance for my 1985 XR this weekend.
1: timing belt + alternator belts
2: water pump
3: radiator hoses
4: intercooler mounts (to replace my zip-ties)
But it just dawned on me that I don't have, and can't find, a lower radiator hose. Is there any "parts store" solution anyone has found while I wait for a proper lower hose to come in the mail?
Are there any tips/tricks people have when doing the timing belt or getting the water pump to seat & seal?
Thank you!
-J
oemoilleaks
Re: Lower Radiator Hose (and other cooling system tips)
Post by oemoilleaks » Fri Dec 07, 2018 3:03 pm
And before I get flamed... I searched the forum, the FB group, and the googles and didn't find anything that seemed to make sense.
Just a lot of "you won't find a hose for an '89"
cmouta
Re: Is there a quick fix for the Lower Radiator Hose?
Post by cmouta » Fri Dec 07, 2018 3:53 pm
The quickest fix would be some sort of universal hose with matching ID's if they stock it:
Chris
zxr250cc
Post by zxr250cc » Fri Dec 07, 2018 5:40 pm
Gates 25255 hose, 20" x 1.25" flex hose....
Post by merkurdriver » Sun Dec 09, 2018 5:03 am
Here's a new 1985-1988 lower radiator hose:
http://merkur.50megs.com/catalog_2.html
Also available in red:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 2521197848
I can get one to you priority mail in 2-3 days. Much easier than trying to fit a one-size-fits-all hose on.
Post by andyofcolumbusmerkur » Sun Dec 09, 2018 10:34 am
That's not a bad deal for that hose. I had to get the universal stainless flex one from summit racing and it was more than 40 bucks. You could try to cut up two different hoses and connect them, but they have to step up a size somehow. Some people have used stuff from the plumbing section of the hardware store. I didn't want to "rig up" something like this and didn't like the idea of chrome coating flaking off and traveling around in the coolant.
Post by andyofcolumbusmerkur » Sun Dec 09, 2018 10:37 am
Also thought I'd mention the "universal" upper hose from autozone dosn't work perfectly. It will have a kink in it, but is ok as an emergency backup. Advanced auto was able to order the 85-88 style upper for me. It's cool somebody is making some hoses for our cars.
oemoilleaks
Post by oemoilleaks » Mon Dec 10, 2018 4:27 pm
I had already ordered one from you!.. I was just being impatient since I had to do all that stuff this weekend. I ended up using the old hose.. It seemed fine. But i'll install that beautiful silicone hose when it comes in!
Post by John Brennan » Mon Dec 10, 2018 6:49 pm
That hose is a super nice piece! If I used one like that, I would be sure to order one while they're available... I would even convert to an Early, new-style rad, if I needed to replace mine, just to look under the hood and see that!
oemoilleaks
Post by oemoilleaks » Wed Dec 12, 2018 1:09 am
yup. as I said, I already ordered it. It just arrived. it looks better in black. can't wait to put it in!
Question though, should I transfer the internal spring over? to retain the rigidity in the bends?
Post by merkurdriver » Wed Dec 12, 2018 4:24 am
I've never transferred that crusty internal spring over. Those corrode and deteriorate...and send little pieces of metal through the cooling system.
16psi cooling system isn't enough to collapse a stock hose in good condition with no other cooling system issues.
However, if yours in in good shape and you want to transfer it, thats fine too.
Post by andyofcolumbusmerkur » Wed Dec 12, 2018 10:41 am
And I can't imagine silicone getting all soft and spongy (needing the coil) like rubber hoses.
oemoilleaks
Post by oemoilleaks » Fri Dec 14, 2018 5:40 pm
Seems better not to transfer it.
