89 condenser fan relay
Larry H
Post by Larry H » Sat Dec 22, 2018 12:28 pm
Hello
My 89 XR has an electrical issue. With ignition off the condenser fan keeps spinning running battery down.
Is this the relays by driver side headlight the issue?
thanks Larry
Larry with Five XR4s and Two Scorpios
Re: 89 condenser fan relay
Post by Ed Lijewski » Sat Dec 22, 2018 1:28 pm
Issue could be a failed coolant fan switch. It's mounted under the lower intake manifold, has a squarish harness connector so not the sensor with a black round connector which is for engine coolant temperature sender.
