Blower motor resistor repair
merk23literturbo
Post by merk23literturbo » Thu Jan 31, 2019 4:17 pm
If your blower only works on high it may be the resistor pack which is accessed from under the hood on top of the blower motor assembly. The thermal fuse goes bad. I found them on line cheap and took some pictures for reference. Taking out the old one is hard. I used a hardened pick to open up the crimped part. Here’s the pictures:
https://photos.app.goo.gl/xLPGmcLW3en1sk6x8
JimG
Re: Blower motor resistor repair
Post by JimG » Thu Jan 31, 2019 6:27 pm
Just don't try to solder the new thermal fuse in, soldering may ruin it!
Jim Gosses
