Saginaw Power Steering Pump Conversion
jkxr4ti
Re: Saginaw Power Steering Pump Conversion
Post by jkxr4ti » Mon May 27, 2019 11:14 am
So the Astro pump is key here because it uses a straight snout vs the majority of the Saginaw pumps that have the tapered version. Were there other Saginaw pumps with a attached reservoir and a straight snout?
That and the horseshoe adapter bracket really make this a bolt on affair aside for the clearance of the bracket.
Great work Brad.
Post by DPDISXR4Ti » Mon May 27, 2019 11:43 am
Great work Brad.
Actually, from what I've observed, most all of the Saginaws use a straight shaft, not tapered. That's certainly the case with the one I now have on my F-150, which does indeed have an attached "canned ham" reservoir. That was a much easier swap though, as the Saginaw pump is used on the Ford E-series vans, so I was able to just grab everything (pump, bracket, hose) from the donor van.
I think there are clearance issues trying to use the horseshoe adapter bracket with anything other than the remote reservoir pump. I didn't investigate it much - it's just what I was told. I considered trying to make my own adapter bracket from an Astro bracket, but I quickly realized that would be a futile project. I have a spare Astro pump at this point - if you want it for $20 I'll bring it along with me to Carlisle.
Post by my8950 » Tue May 28, 2019 8:01 am
John Brennan wrote:
Thu May 23, 2019 9:21 am
I admire all the work you've done on this, Brad, especially the exquisite documentation. I wish I had that kind of spare time.
Agreed, documentation here and then a final parts list...
Post by DPDISXR4Ti » Tue May 28, 2019 2:07 pm
I've put about 40 miles on the car, which I'm calling "good enough" for the upcoming 500-mile test. The pump is all but silent, even under low-speed turning maneuvers. I'm happy with the final results.
Post by DPDISXR4Ti » Sun Jun 09, 2019 11:01 am
The pump passed it's 500-mile test last week with flying colors. I was a little apprehensive about using a 3/8" barbed fitting to "create" a hybrid hi-pressure hose, but it has not leaked at all - bone dry on either side of the fitting. Maybe some day I'll have a hydraulic hose shop make up a hose, but for now all is well.
Post by Ed Lijewski » Mon Jun 10, 2019 4:43 pm
1,000 mile circuit next: Tuxedo to Saginaw to Detroit and return home.
Post by DPDISXR4Ti » Fri Jan 24, 2020 11:35 am
I'll create a listing when I get a chance, but I realized yesterday that I've accumulated a second batch of most of the parts you need to do this swap, which I'd be willing to sell. At his point I have the following:
- Astro pump w/ Reservoir
- Lower pressure regulator from Saab
- Pulley with correct offset
- Spare bracket for "re-fabrication"
Drop me a PM if interested.
