Weighing options with exhaust
I am trying to make a decision on how I want my exhaust done. No matter which way I go, I will have an entire 3" system with a mandrel bent 3" DP, a high flow cat, and a straight through muffler. What I'm trying to decide is weather I'm going to do a crush bent cat-back, or spend the extra $$$ for mandrel. Anybody know how big of a difference I would notice with the mandrel?
If you really want to be anal and get almost close to the same numbers as mandrel, you could always do crush bent 3.5" corners and then the rest in 3".
Hell, how many bends are there in your exhaust system? I've seen one with only one bend, and that was about 15* at that.
Are you going above the control arm or below? Side exit? Left rear? Right rear? Duals?
Just tossing some ideas out there.
Personally, I'm looking at 4" downpipe to 3" cat, to 3" straight through muffler... then I'm undecided about the exit.
Here is an option http://projecthp.ford23.com. Mandrel bent 3" can get it in duals or a single. This is just the pipe from the turbo all the way back. You have to add the cat and muffler if you want them.
Last time I checked duals were 270 including shipping and I think the single was 240. I'm thinking about going this way if I don't have my buddy here at work take my car to the race shop and fab me up one, but he can't do the mandrel bends. Of course for me no cat
, and was thinking of a supertrapps at first but not sure now also with the dual setup.
I think that as long as your downpipe is mandrel, and your (hi-flow) cat inlet is 3", it won't matter much if you have crush-bent, 3" dual cat-back stuff. As there are two of them, the area is increased, even though the split to duals is a minor restriction. I would put more emphasis on the elbow, as I think that's the most critical point left to you.
- Mike McCreight
Hey!
I didn't know Sac. Mustang was building an "elbowless" downpipe.... Anyone fitted one of these yet?
Mike.
Mike.
I didn't either-- hmm! I wonder how well it fits the XR; the Fox car has some different measurements. Although I believe their downpipe is the best on the market, it needs to be modded a little to fit really well on an XR.
I didn't know that either. I went and looked, I think I'm sticking with a Bob's elbow, over 300 cheaper. I still want to put a flange on it though for easier removal, since you know it will have to come off for something (like the turbo, head gasket, etc..). Or my other option is to see if Stinger can do the elbow if I get the whole exhaust from him.
- Varthlokkur
- Level 2
Ix-nay on at-thay... it isn't the case. All else being equal, a single flows a little better than duals in this application.merkd-ya wrote:i remember reading that rapido's dual gave an aproximate 20hp increase vs the 10hp increase of their single 3 inch... any comments?
Luke, since this thread goes back a ways, I presume you're onto the bennies of JVL's Cossie exhaust housing?
Yep, that's precisely what he's building for me right now. Basically, one of these, but with a V-band flange on it...edge wrote:I think I'm sticking with a Bob's elbow, over 300 cheaper. I still want to put a flange on it though for easier removal, since you know it will have to come off for something (like the turbo, head gasket, etc..).
