Shaky
hotrodtodd68
Shaky
Post by hotrodtodd68 » Fri May 17, 2019 10:47 am
Hey guys. It looks like you’re still here. What do you think this shaky shaky is?
https://youtu.be/o70esX4BMaM
https://youtu.be/oB6xmeDQbOc
https://youtu.be/UaSGyZyTcbU
88 2.3T Mustang, 85 XR4Ti("Humpty-Dumpty"), 86 XR4Ti(someday project), 02 Wrangler Sport, 68 Firebird(red,fun), 71 GMC1500(dumprunner), 93 Geo Storm GSi ("Stitch"), 65 Mustang Convertible, 12 Dodge Challenger R/T ("the fast car"), 12 Toyota Highlander ("the lux-o-barge")
Re: Shaky
Post by my8950 » Fri May 17, 2019 2:38 pm
I think its not available....
hotrodtodd68
Re: Shaky
Post by hotrodtodd68 » Fri May 17, 2019 7:36 pm
I fixed the links. Apparently Facebook links don’t work.
Re: Shaky
Post by andyofcolumbusmerkur » Sat May 18, 2019 9:01 am
It looks like you found the problem while it was on the lift.
Re: Shaky
Post by my8950 » Sat May 18, 2019 11:01 am
Looks like you're wiggling something...What was the issue?
Re: Shaky
Post by Ed Lijewski » Sat May 18, 2019 2:13 pm
Worn inner tie rod ball joint.
Merkurstein
Re: Shaky
Post by Merkurstein » Sat May 18, 2019 5:48 pm
Yeah tie rods needed for sure! Just changed mine too. Has the tires been setting for awhile?
hotrodtodd68
Re: Shaky
Post by hotrodtodd68 » Sat May 18, 2019 11:04 pm
yeah thanks maybe it is the inner tie rod ends
The tires had been sitting which might make it worse but I had this problem before I parked it. It’s weird like it’s worse under load like going uphill. I checked the guibo and it’s ok too.
Re: Shaky
Post by my8950 » Sun May 19, 2019 9:13 pm
Hmmmm, this actually makes me wonder if mine has the same issue.
Mine is nowhere near this bad, only does it when I brake.
Front brakes are new, tie rod ends are new, but still does.
I was thinking control arm bushings, but maybe inner tie rod ends?
