Euro/horn turn-signal switch conversion to our turn-signal switch with cruise:
itking
Post by itking » Sat Jun 15, 2019 8:15 am
Here's some pictures & comment of what I did. I have it currently working perfectly in Raven.
Ron
1968 Dodge Charger 383
itking
Re: Euro/horn turn-signal switch conversion to our turn-signal switch with cruise:
Post by itking » Sat Jun 15, 2019 8:17 am
First it took apart the broken switch with cruise cause I needed the pin with the tab.
Note. You will have to drill out the rivits carefully.There are 2 other pins that each have tabs which can be used to make the same pin/tab combo. So 1 broken cruise switch can be used to modify 3 euro's.
Ron
itking
Post by itking » Sat Jun 15, 2019 8:20 am
You will have to remove the wire with a solder gun. Carefully use a Dremel to cut the bent metal piece out of the way in the channel the wire will follow up to & to also make a indentation so the tab will be flush with the plastic.
Ron
itking
Post by itking » Sat Jun 15, 2019 8:21 am
The solder wire to tab, carefully press pin in place while guiding the wire in the channel.
Ron
