2.3t for 5.0w swap. Anyone interested?
reddy2300
Post by reddy2300 » Tue Oct 22, 2019 5:29 pm
It seems I can't let go of doing another 5.0/XR swap. I have a ~75k mile 87 XR with some "ok" engine mods. (Bolt-ons...IC, PE computer, 3" mandrel bent Stinger exhaust...) Also have the T9 and short throw shifter.
I'd like to find a 5.0/T5 from a Foxbody that's in similar condition. With harness/computer, etc. Doesn't have to be anything special. Just low mileage and runs as good like the turbo 2.3 does.
Is this a realistic "ask"?
Any takers?
1987 5-speed XR4ti-70K mile "barn find", Rosso Red, Grant wheel, short throw shifter, PE/big VAM, 255lph pump, 3" Stinger/Magnaflow exhaust, MD "shorty" radiator/IC, fake BBS wheels, Koni Yellows, Rapido sway bars, poly/aluminum bushes, Gillis valve,
Re: 2.3t for 5.0w swap. Anyone interested?
Post by andyofcolumbusmerkur » Tue Oct 22, 2019 10:49 pm
I think it makes sense to keep the original engine in there since it is fairly low mileage. But I also think it makes sense to put an LSX in just about everything since they seem to have so many good qualities.
reddy2300
Post by reddy2300 » Wed Oct 23, 2019 10:23 am
Take that crap Chevy talk somewhere else. I want to keep the car nice.
#neverchevy
Post by my8950 » Wed Oct 23, 2019 12:39 pm
There is a guy close to me that is always parting Mustangs with the 5.0 and trans. I'm sure you can get one easily and swap it over if that's what you want to do. It's been done before, and I'm pretty sure there are a number of others who've done it. Pat Sprague, Chuck, being a few...Although, I think both of these are from an SN95, so that's a little different than the previous Fox platform. Do it if that's what you want to do.
I'd think a mild build 5.0 would be the same as a 2.3T roughly, it would provide enough power and torque to run the car decently...
reddy2300
Post by reddy2300 » Wed Oct 23, 2019 7:09 pm
I’ve built a 5.0 powered XR in the past. That’s not what this post is about. I’m looking for someone who may have a good engine and trans.
Post by my8950 » Wed Oct 23, 2019 7:54 pm
Look on corral, or your local CL.
Post by andyofcolumbusmerkur » Wed Oct 23, 2019 9:40 pm
At least I didn't suggest the BMW V8.
Post by andyofcolumbusmerkur » Wed Oct 23, 2019 10:18 pm
Now I understand, you want to trade engines with another person. Maybe someone out there has an svo that needs a long block, and a lose 5.0 or 5.0 donor car parked. Not a ton of turbo 2.3 engines available so I guess it's possible to find the right person.
Post by my8950 » Thu Oct 24, 2019 7:56 am
Ah, is that the case? I didn't get that....I think that would be a tough trade to find. May be better off the just find and buy the engine/trans setup desired, and then sell the 2.3 setup. My guess is that not the same person would want to do the opposite trade. Most guys swapping engines on a 5.0 are going LS or Coyote, not downsizing to the 2.3...
reddy2300
Post by reddy2300 » Thu Oct 24, 2019 4:48 pm
Yeah. I'm not relying solely on this type of trade to procure the parts. Just floating it out there to see what I can find. I do know that I can find the parts on MarketPlace/CL and even the JY. But, if someone wants to do a trade, it's what I'd prefer.
The only people who do 2.3t swaps aren't just Merkur guys. Plenty of guys with Rangers and non-turbo 2.3 Mustangs could benefit from that swap. And some of those guys have 5.0 parts sitting around.
I would still like to build a "Boxtop" Fairmont with a 2.3t and T5.
Post by my8950 » Sun Nov 10, 2019 12:43 pm
Find a 5.0? I've seen about 4 5.0's posted since the last post. Fairly cheap too...
Merkurfast
Post by Merkurfast » Sun Nov 10, 2019 8:22 pm
Best to get a 5.0 out of a Explorer as they came with GT40 heads and shorter accessory drive.
reddy2300
Post by reddy2300 » Wed Dec 04, 2019 4:30 pm
GT40p heads. Which requires a different header. And then, when you buy heads, you'll need yet another header, as most "P" head headers don't play well with most aftermarket heads.
Post by thesameguy » Wed Dec 04, 2019 5:16 pm
1000%!
