Yeah, MK Motorsport sold all their Sierra/Cossie stuff to Anembo.thesameguy wrote: ↑Mon Dec 21, 2020 2:38 pm ...
Also:
https://anemboengineering.co.uk/ford-si ... b-2wd-4wd/
It's as if someone thought long and hard about which diff would work well, with simple spacers that are the same on both side and the offset is perfect with the spacers to be the exact same width as the Ford Euro 7.5". That credit does belong to John V. A few places in the UK magically started manufacturing an identical kit only a couple months after one of JVAB's one was sent across the pond.john keefe wrote: ↑Mon Dec 21, 2020 3:30 pm ...But, I like the Supra diff conversion kit with the precision stub axle adapters so you can use the stock (RS) CV's. Speaking out of ignorance, though, I wonder how much stronger it really is compared to the Ford 8.8 swap...
As for strength, they're comparable to the 8.8. The problem is cost: John's kit cost under $400, add the diff for around $200 max (already has good gearing and LSD), and then figuring the driveshaft for around $400-500 of modifying the stock one (I would never use the stock joints, even if replaced). The rest was bolt-in. Can even use GTO axles without mods and Cossie stub shafts (or my GpA style setup ). 8.8 kit cost a lot, mounting was difficult requiring fabrication or sending beam to get modified; axles were custom, so if you break one, get out your wallet and wait a little while for a replacement; diff assembly only came with good gears and an LSD in the 03-04 Cobra (3.55 only, 3.27 for the 99-01 Cobra), so cost a lot to get good gears and LSD installed and set up. You're spending at least twice as much for almost no gain. It's a nice setup, would never argue that.
There's my rant/.02
