End of the rope with my '88
toffeepeanuts
Post by toffeepeanuts »
Its now been over a month since my '88 XR decided to kick the bucket on the highway. On that day, it ran completely fine ALL DAY with no hiccups whatsoever. When it died, it ran fine and then all of a sudden I lost power and the engine sounded different. Fast forward to now, it is still dead and I have genuinely no idea what to do now.
Currently, the engine will run, albeit VERY poorly, and it smells heavily of gasoline.
YES, I've verified cam timing is set to spec at TDC (it is)
YES, I've verified distributor timing is set to spec (it is)
YES, I'm getting 40 psi of fuel to the rail and injectors
YES, I have spark on all 4 cylinders
YES, the TFI module, ignition coil, and wires are all fine
The only thing I haven't been able to verify is compression. Why? Because the compression tester I have doesn't fit for no reason other than to piss me off even further. Knowing my luck, that's exactly where my problem lies and I can't even test it to find out.
Please someone help me before I push this thing off a cliff with me in it
Re: End of the rope with my '88
Post by thesameguy »
You can rent a compression tester from Autozone or Oreillys...
MarkM
Post by MarkM »
I don't see any mention of engine trouble codes.
Mark
MarkM wrote: Wed Aug 11, 2021 9:25 pm I don't see any mention of engine trouble codes.
Yes. Scan it. You could just have a bad coolant temp sensor for example. This will keep the car from running if the computer does not get a signal. You can unplug the one for the fans or the one for the gauge but the computer needs it's coolant temp input. Great sneaky kill switch wire to splice into, sneakier than splicing into the fuel pump(s) which is pretty common.
You do not pick Merkur, Merkur picks you.
Pull the vacuum hose off of the fuel pressure regulator and sniff the end of the hose; if it smells of gasoline its diaphragm is bad.
When you removed a spark plug(s) what did they look/smell like?
Post by my8950 »
Location?
toffeepeanuts
Yeah, my mistake. I hadn't even thought about getting a scanner. My last eec iv Ford had an actual check engine light (89 Mustang) so it hadn't even occurred to me.
Ed Lijewski wrote: Thu Aug 12, 2021 9:53 am Pull the vacuum hose off of the fuel pressure regulator and sniff the end of the hose; if it smells of gasoline its diaphragm is bad.
They were slightly black from carbon but didn't have any major issues as far as I could tell. One was oily but my VC leaks about right in top of it.
my8950 wrote: Thu Aug 12, 2021 3:09 pmLocation?
Northwest Missouri
My car had a cheapy parts store (white plastic) PCV valve installed by a previous owner. It blew out the guts under boost and the car ran really bad bucking and jerking. Put the real deal Motorcraft one on it no problems since. Except for things like turn signals, power windows, brake lights etc. But I don't mind having to fix a few things now and then since the car is so fun. Boost comes on like a switch and throws you back into the seat. When you get the car working you will be glad you didn't push it off a cliff.
You didn't rely re the fuel pressure regulator (do you know what/where it is?).
toffeepeanuts
andyofcolumbusmerkur wrote: Fri Aug 13, 2021 6:03 pm My car had a cheapy parts store (white plastic) PCV valve installed by a previous owner. It blew out the guts under boost and the car ran really bad bucking and jerking. Put the real deal Motorcraft one on it no problems since. Except for things like turn signals, power windows, brake lights etc. But I don't mind having to fix a few things now and then since the car is so fun. Boost comes on like a switch and throws you back into the seat. When you get the car working you will be glad you didn't push it off a cliff.
Yup. I have a new Motorcraft PCV on mine. PCV valves are one of the first things I do on any new cars I buy, especially if they're old cars (and they always are). Cheap insurance, y'know?
I definitely would rather get it going and not let it sit anymore.
We are really just blindly throwing darts at this point. I would guess if you scan it you will find out the vam or something is the problem. Ed he says he is getting 40 lbs of fuel pressure so it doesn't sound like that is an issue. As long as that pressure is not intermittently dropping off like when actually driving around. Not sure if OP is using a gauge under the hood or has a fuel pressure gauge permanently installed in the car.
I was responding to that.
toffeepeanuts
andyofcolumbusmerkur wrote: Sat Aug 14, 2021 8:26 am We are really just blindly throwing darts at this point. I would guess if you scan it you will find out the vam or something is the problem. Ed he says he is getting 40 lbs of fuel pressure so it doesn't sound like that is an issue. As long as that pressure is not intermittently dropping off like when actually driving around. Not sure if OP is using a gauge under the hood or has a fuel pressure gauge permanently installed in the car.
I used a pressure gauge under the hood attached to the fuel rail
I used an obd1 scanner. I got the following codes with the engine running: 12 34 41
reddy2300
Post by reddy2300 »
Soooooooo, what does the book that came with the code scanner say about those codes?
1987 5-speed XR4ti-70K mile "barn find", Rosso Red, Grant wheel, short throw shifter, PE/big VAM, 255lph pump, 3" Stinger/Magnaflow exhaust, MD "shorty" radiator/IC, fake BBS wheels, Koni Yellows, Rapido sway bars, poly/aluminum bushes, Gillis valve, Eurolights,
https://www.troublecodes.net/ford/eec-iv/
Ed might be right and you are lean because of a bad fpr
