Finaly did something on the XR
wilky
Post by wilky »
Thought you guys might be interested in my hood mod to provide an air outlet for my "updraught" IC:
Did this today while FastFord87 replaced the rear wheel bearings and continued with his fabrication of a 3" exhaust system. (Yeah, I had fun whilst he did all the hard, dirty work!
Wilky
Seeking relationship with sexy lady Merkur owner (send pic of Merkur).
M E R K U R
Post by M E R K U R »
very very nice!
"Nitrous is like a hot girl with STD’s… You know you want to hit it, but you’re afraid of the consequences"
Colin
Post by Colin »
Nice work! Is that a pre-fabbed part moulded in or was it made from scratch? Either way, it looks great. :)
Colin
Instagram @colinrdoyle
File to fit, paint to match.
minitrucker
Post by minitrucker »
Wow, that is mighty fine work.
This is my bucket:
Sock
Post by Sock »
Colin wrote:Nice work! Is that a pre-fabbed part moulded in or was it made from scratch? Either way, it looks great. :)
Colin
Made it himself. I was there for the middle-end of it.
wilky
Post by wilky »
AlexD wrote:Are you going to keep it open or put some screen on it
Nah no screen needed - air is coming out of this hole (well that's the theory anyway) and all you'll see do0wn there is a suitably polished little Cossie IC.
Wilky
wilky
Post by wilky »
Colin
It's a home made metal job. I just cut a flap the shape of the opening with a dremel and bent the flap down over a piece of plastic pipe to get the right bend radius. I then cut some sheet metal in a "U" shape and welded it to the hood & flap. The corners were filleted with bondo to give it the desired shape (and cover my $#!%^& welds) and the whole thing sanded down. The longest part of the job was figuring out what shape it had to be. It could be done just as well using pop rivets rather than welding & shouldn't take more than a day to get it to the paint prep stage.
Wilky
Colin
Post by Colin »
Well damn - you're quite the fabricutioner! :D
Excellent! But you're still bringing the Cossie to Carlisle, right David? Is this one coming too???
Black94 5.0
Post by Black94 5.0 »
That looks really good...I had ideas of doing that exact thing, it would be pointless for me to do it right now since I don't have an IC...hehe...Your design looks really functional
How close is your timming belt to the back side of the vent?....You'll have to show us some pics after it's painted...
Nice job!....
*Bilsteins, MC2 250# coil overs front, 600# rear, BAT sway bars, full 3" exh, Gillis valve, K&N, MC2 Diff mount and bushings, 17x7 Team Dynamics Monza's, 225/45-17's, Eaton Posi, RS500 (clone) intercooler/radiator, Forge BOV and LA computer and big VAM...
xr4time
Post by xr4time »
don't you get mostly hot air coming off of the radiator?
Wandering in search of...
mangostick
Post by mangostick »
I think Wilky's goal here is to draw cool air through the grille/ic and out of the hole in the hood...it should work too...the front of the hood and grille create a high pressure area and where the hole is should have a slightly lower pressure (read vacuume) so in effect to pull air through the IC...hmm I think someones on to something here...
where'd I put that damned hammer?? :-D
Shawn Mangan
KingpinCEO
Post by KingpinCEO »
what size radiator u using?
1985 Merkur XR4Ti - 2.5 ranger block greyhound bus turbo
1988 Mercedes Benz 190e - awaiting airbag suspension
2005 Dodge Magnum - 336,000 Mile Daily driver
2008 Subaru Legacy GT - crazy loud boxer rumble
2009 Suzuki GSX650F - crotch rocket
ig: @DJ_Kingpin
wilky
Post by wilky »
Black94 5.0 wrote:How close is your timming belt to the back side of the vent?
there's about 2.5 inches of clearance.
Wilky
wilky
Post by wilky »
mangostick wrote:I think Wilky's goal here is to draw cool air through the grille/ic and out of the hole in the hood...it should work too...the front of the hood and grille create a high pressure area and where the hole is should have a slightly lower pressure (read vacuume) so in effect to pull air through the IC
Yup, you got it. There is a low pressure area where the vent is (thats why the Cossies have the vents there).
Wilky
