Rapido Big Valve Head
jkxr4ti
Post by jkxr4ti » Fri Sep 09, 2005 3:49 pm
I have a big valve head from Rapido purchased back around 95. It came complete with new cam A231 wich i understand is the same cam as in the later xr's. It also has the double valve springs.
I was wondering if Rapido's big valve heads were actually from ford or if they had stockers upgraded with bigger valves? If this is indeed form ford, did those motorsport heads have different casting numbers from the stock XR heads?
Peter C and I spoke at the Glenn a little about this as he recently purchased a big valve ford head from Ebay. We were both wondering if there was any way of identifying one?
xrian
Post by xrian » Fri Sep 09, 2005 3:56 pm
Nothing special. It is just a stock casting that was rebuilt by MP using larger valves. Some had "O" rings cut into the head. Mild port work work was done but still much room for improvement. If it used the MP roller cam which had no base circle, you would need to do much reworking of the valves before a normal type cam could be used.
In a nut shell, you'd be way better off spending the $$ on an aluminum Essy head.
Ian G-J
Ontario, Canada
Post by anglin » Fri Sep 09, 2005 4:17 pm
xrian wrote:It is just a stock casting that was rebuilt by MP using larger valves. Some had "O" rings cut into the head. Mild port work work was done but still much room for improvement.
Hargh? So what you are saying is that Rapido was getting their big valve cylinder heads from Modern Performance in 1995? If this is true, this is amazing.
jasonty
Re: Rapido Big Valve Head
Post by jasonty » Fri Sep 09, 2005 5:29 pm
to the best of my knowledge, the old rapido big valve head was the FMS head. i dont know what there talking about in the other replys.
jkxr4ti wrote:I have a big valve head from Rapido purchased back around 95. It came complete with new cam A231 wich i understand is the same cam as in the later xr's. It also has the double valve springs.
jason yancey
stephens city va
87XR-88XR
NOVAMOG
fastmaul
Post by fastmaul » Fri Sep 09, 2005 9:51 pm
That it made any power?? yeah, I agree...LOL
xr4racing
Post by xr4racing » Sat Sep 10, 2005 10:56 am
Hi Jeremy (and everybody),
I don't see any firm answer here so far. If somebody knows the story on the 'Ford Motorsport big valve head' please share it.
I recall from being around these cars since the early days of '84-85 hearing that a big valve head was available through Ford Motorsport dealers. My only confirmation of that may be hearing it from Russ at Rapido 20 years ago, and then asking him again recently.
Could be that Ford had some outside shop make the head for them (if there is any such thing that is).
Mine came with the A230 kit (A237 cam, rollers, sprocket), big valves and a few more goodies. My vague recollection from 20 years ago matches that the Motorsport head came with the A230 kit.
Yes you could just build a big valve head with the same parts or whatever parts you want.... but what we're trying to do here is confirm there is such a thing (as a big valve head from Ford), and how to identify one.
Although I vaguely recall seeing it listed in a Motorsport catalog.. that could be my imagination. Anybody got the catalogs they can look through for us or any other confirming info? Jason??
Thanks,
Peter
XR4Ti-IMSA
MarkM
Post by MarkM » Sat Sep 10, 2005 12:44 pm
From the 1994 Motorsport catalog:
2.3L OHC Cylinder head assembly - M-6049-A231
Here's a great package for "bolt on and go" fans. Cast iron cylinder head features "D-shaped" intake ports with combustion chamber volume of 62.4cc. Intake valve shrouding had [sic] been deleted. Cylinder head is machined to accept motorsport valves. Current heads include exhaust valve seat inserts. The assembly comes with the following motorsport components:
M-6507-B221 Intake Valves (4) 1.89" Dia.
M-6505-B221 Exhaust Valves (4) 1.59" Dia.
M-6250-A231 Camshaft (1)
M-6513-B221 Valve Springs (8)
Also included are (8 each) of the following production-type parts: Tappets, Valve Stem Seals and Valve Rocker Arms.
Mark
GeneticRehab
Post by GeneticRehab » Sat Sep 10, 2005 9:07 pm
Well I just happen to have my 94 catolog here on my desk. It has not moved off of here sence Carlsile. LOL. Everything that Mark typed out is correct. Here are the cam specs though:
Hydraulic. Flat tappet int=268 exh=268 int lift .400 exh lift .400
I really don't think that the casting number is any different that any other turbo d-port head. Unless you look at the ranger dual spark head. But I may be wrong. I'm aways wrong. So don't rely on me. Lol.
Did you know that you could have bought a Cosworth 2.0 n/a motor from Ford in 94. Here is the part number for that one for the needy M-6002-C200*
Just my .02 cents IOU.
Oh. and were you refurring to me as Jason? He said refur. LOL.
Jason Liss
1989 XR Still in pieces
1986 XR Sold!
jasonty
Post by jasonty » Sat Sep 10, 2005 10:18 pm
im 100% positive that the Rapido head was the same as the FMS head. i was looking at an old SVO cat and the Rapido cat. today. Now the question is ...did Ford make the head, or did Esslinger do it? in the 99 SVO cat. there is also the Esslinger Alum. Head..
xr4racing wrote:Hi Jeremy (and everybody),
Thanks,
Peter
XR4Ti-IMSA
jason yancey
stephens city va
87XR-88XR
NOVAMOG
LS2XR4
Post by LS2XR4 » Sun Sep 11, 2005 2:47 pm
rapido sold the FMS head. the sell ford motorsports parts. what so hard to understand.
the head was done by ford end of story. the essy head in the catalog was available through ford motorsports catalog but it came from essy.
essy was not doing "turbo stuff" back then.
Snake
Post by Snake » Tue Aug 01, 2017 5:10 pm
The aftermarket iron head B Chandler mentioned was available from SVO Motorsport back in the day. They discontinued it sometime in the mid to late 90's. It was an iron head developed in the 80's by SVO Motorsport with help from Esslinger. It had improved intake and exhaust ports for better flow, Larger valves, Thicker deck surface, and a few other features that escape me at the moment. The part number was M6049-A231. So if you happen to run across one of these heads in good condition at a reasonable price it will give you abit more power over the stock head and be a nice piece of nostalgia.
Post by DPDISXR4Ti » Thu Aug 03, 2017 4:15 pm
Holy 12 year-old thread re-ignition! :shock:
I don't recall this thread, and I certainly don't recall Ian's claim that MP built the big-valve FMS heads! Not sure what he was thinking that day.
Post by merkurdriver » Fri Aug 04, 2017 1:21 pm
DPDISXR4Ti wrote:Holy 12 year-old thread re-ignition! :shock:
:shock:
Right , I was just thinking the same thing....is this what we thought 12 years ago? That would be crazy
jkxr4ti
Post by jkxr4ti » Sat Aug 05, 2017 8:45 am
Well since this thread has been revived I guess I'll give an update.
The FMS big valve heads definitely don't have hardened valve seats.
I had this resurfaced a few years back and the machinist said the valves had
sunk into the seats. He builds mini stock motors and said the fms head was mostly aimed at that market and most likely why standard seats were installed in those heads by ford.
He replaced them with new seats and the head is back on the car.
So far it's been on 2 vehicles and roughly 60k miles. The seats were replaced at about 30k miles.
