Emergency Brake Cable Removal
- Level 2
Like the subject says...can the emergency brake cable be removed? I'm dropping the entire rear to replace just about everything and would like to disconnect the emergency brake.
Thanks
Keith
Thanks
Keith
'86 XR 340rwhp @ 5k
'05 STi dp, hdr
'05 Freestyle CAI
'05 STi dp, hdr
'05 Freestyle CAI
e brake
Well it can be removed. When I picked up my xr4 one side was broken and the bell crank attached to the ebrake handle was bouncing off the drive shaft . But couldn't get the cable off . So I took the center consold out around the ebrake handle unbolted it and pulled it up enough to see the aluminum press rivet that the small shaft connects to the handle and drilled it out. the cable dropped free and I Just popped off the rear drums and removed the cable. And you can replace the small Rivet with a bolt . Just have to remember to get a new ebrake cable of of these days.
88 maroon xr4ti,
88 xr4ti now blue.
88 xr4ti black,
88 xr4ti red,
88 xr4ti white.
Can I stop now I'm broke.
88 xr4ti now blue.
88 xr4ti black,
88 xr4ti red,
88 xr4ti white.
Re: e brake
Thanks for posting this. So you're saying that short of removing the entire assembly, the only way to get it disconnected at the lever is to drill out the rivet?Specktor wrote:Well it can be removed. When I picked up my xr4 one side was broken and the bell crank attached to the ebrake handle was bouncing off the drive shaft . But couldn't get the cable off . So I took the center consold out around the ebrake handle unbolted it and pulled it up enough to see the aluminum press rivet that the small shaft connects to the handle and drilled it out. the cable dropped free and I Just popped off the rear drums and removed the cable. And you can replace the small Rivet with a bolt . Just have to remember to get a new ebrake cable of of these days.
ebrake
On mine I couldn't find any other way to get it off . Supposedly the shaft that I was discribing I think was threaded and has a nut to hold the belt crank on it ,mine was damaged from hitting the drive shaft so I can't confirm it. But there should have been , its the only thing that would make sense
88 maroon xr4ti,
88 xr4ti now blue.
88 xr4ti black,
88 xr4ti red,
88 xr4ti white.
88 xr4ti now blue.
88 xr4ti black,
88 xr4ti red,
88 xr4ti white.
- Level 2
Anglin and Grayson wrote up some directions as part of the rear beam mount bushing install on their www.mc2racing.com web page as well. Seems like no drilling/cutting isn't normally required but the components can get pretty corroded and beat up.
'86 XR 340rwhp @ 5k
'05 STi dp, hdr
'05 Freestyle CAI
'05 STi dp, hdr
'05 Freestyle CAI
- Mike McCreight
That pin can really get stuck in there... Ian suggested putting a socket behind the bracket that connects to the E-brake handle so the pin would have somewhere to go when you pound on it. Had to drop the exhaust to get at it, but his trick worked great. My winter beater's cable snapped last spring, and I too had to drive around with the handle up to prevent the thing from rattling on the driveshaft. I managed to get quite a few E-brake cables, and promptly replaced them on all my XRs...
Anyone need a NEW E-brake cable??
- Level 2
- Mike McCreight
$65!!fast_xr4@yahoo.com wrote:What's the cost? Mine looks like hell froze over, salted and thawed. Winters in Ohio are brutal.
