RS500 intercooler
svo855
RS500 intercooler
Post by svo855 »
Do you have to remove the AC condensor to install an RS500 style intercooler?
William P Copeland
Insane Ford 2300 & rotary engine freak
Yes.
svo855
Post by svo855 »
Well that truely sucks. What are my options if I want to keep the AC? I am not shooting for a small power number but I'll be damned if I will drive in Dallas traffic, and in Texas heat with no AC.
William P Copeland
Maurice S
Post by Maurice S »
You can use a short Saab Turbo or Scirocco rad with an Cossie Sierra or Escort or Escort Turbodiesel I/C above it. Or a Porsche 944/951 type of thing...I was wondering if you could use the RS500 one or like a Volvo BIG but thin like 1" one ahead of the rad but moving the stock rad back a couple of inches to make room and just routing the the compresor tube over the valve cover to the drivers side tank and the TB tube prttey much straight back and a 90 bend to the TB from the pass side tank? But thats a project.
turbofan
Post by turbofan »
Maurice S wrote:You can use a short Saab Turbo or Scirocco rad with an Cossie Sierra or Escort or Escort Turbodiesel I/C above it. Or a Porsche 944/951 type of thing...I was wondering if you could use the RS500 one or like a Volvo BIG but thin like 1" one ahead of the rad but moving the stock rad back a couple of inches to make room and just routing the the compresor tube over the valve cover to the drivers side tank and the TB tube prttey much straight back and a 90 bend to the TB from the pass side tank? But thats a project.
you can, but those big and thin volvo coolers SUCK. they're inefficient, flow poorly, and just aren't what everyone thinks they are.
i'd say porsche 944 or cossie would be the way to go.
i *know* i've seen a pic where somebody ran the tubing across the engine bay like that, but i think it would be better to just rotate the intake.
Ed (yep, another Ed....)
flylear45
Post by flylear45 »
Like this?
Jim Franks
Merkur-less for now
member of the Bowling-Grippo fan club
2.3 turbo TR7 http://home.roadrunner.com/~jimmble/
turbofan
Post by turbofan »
that's not the same one i'd seen before, but yes, just like that. that looks pretty nice!
Maurice S
Post by Maurice S »
There you go...and the Volvo I/C while not great is better than the top mount with no scoop or some cheesy deal you know...And rotating the intake, that's another project...I'm thinking of going with something similar to the above...I'm not looking to make huge power. And with a BOV/BPV the tubing shouldnt be a problem...not really excessive I dont think anyway.
There's always the Rapido IC, or a TCIC front-mounted, Saab 900 fender or battery-spot mounted, and several others. I think the Cossie rad over a shorty rad is your best bet, or perhaps a force-fed TCIC. My DG IC over C&R rad let me keep my A/C, but good luck finding one of those.
SARON81
Post by SARON81 »
Or you could go bottom mount. Here's what I have in my black car. It was made by a company here in Baltimore. It's very nice to have cold AC.
turbofan
Post by turbofan »
do you have any better pics of that? like.. of the intercooler and how you mounted it?
johnny b, the saab 900 is a pathetic intercooler by comparison to many, and the rapido has too much tubing. if you were to ditch the saab 900 endanks, or at least redo the turnaround part of the entanks (that endtank is much too small and restrictive) and make sure to use the later intercooler, it would work ok. but the dual pass is never a good design.
He could also go the Hartwood Intercooler/Radiator combo route.
http://www.merkurclub.com/forum/viewtop ... ntercooler
If I lived in a heat and humidity hell hole as Dallas can be and usually is, I would think and look in that direction. :wink:
YMMV 8)
Did you catch the part where he said he's "not looking to make huge power"? There are other priorities in play here. The 900 flows well, and moreover is compact and highly adaptable to space-limited mountings.
Sometimes, a smaller core mounted properly and fed high-pressure air is as good or better than a big one mounted less than ideally.
svo855
Post by svo855 »
John Brennan wrote:Did you catch the part where he said he's "not looking to make huge power"? There are other priorities in play here. The 900 flows well, and moreover is compact and highly adaptable to space-limited mountings.
I said that I was not shooting for a small power number. 430-470 hp at the wheels is about what I want. I have a dyno only air to water setup now but now this car has to be road worthy. I will just buy an RS500 style IC from across the pond and I will make it work.
My goal was to find something off the shelf so I wouldn't have to reinvent the wheel. Damn these cars; why does everything with them have to be a fight?
William P Copeland
JediTalen
Post by JediTalen »
BAT sells a unit that mounts parallel to the ground in front of the steering crossmember, it uses the natural flow of the engine compartment to draw air through you wouldn't have to change any of your radiator/ac stuff at all for this one.
No-really I can stop bringing home XR4's whenever I want....
I um......sorta.....um.....like....have seven now.....and a couple Scorpios....
