fuel pump
1lowscort
fuel pump
Post by 1lowscort » Fri Nov 17, 2006 1:13 pm
what is the fuel flow rate on a stock fuel pump? anybody know...i know the early merkurs had the fuel pump mounted outside the tank and that is the one im looking at because thats how my car is built as well
1986 Escort GT
SARON81
Post by SARON81 » Fri Nov 17, 2006 1:20 pm
All XR's have dual pumps. One in the tank, and an inline pump. I'm not sure of the factory flow ratings though.
Post by Mike McCreight » Fri Nov 17, 2006 4:16 pm
Put a Walbro in the tank, (255 LPH) and be happy...
Frag
Post by Frag » Fri Nov 17, 2006 4:38 pm
It's somewhere around the 90lph range no idea what PSI or what. It should be good to 250hp.
1lowscort
Post by 1lowscort » Fri Nov 17, 2006 5:14 pm
my fuel pump is external or i would do the walbro 255..im now considering changing out for the later in tank fuel pump because ive been hearing nothing but bad things about external pumps.
1986 Escort GT
Frag
Post by Frag » Fri Nov 17, 2006 5:24 pm
*shrug* I replaced my external pump with a larger in-line bosch motorsport pump. It's louder on startup and when running but other than that it seems ok to me.
GeneticRehab
Post by GeneticRehab » Fri Nov 17, 2006 6:07 pm
I put a 255lph high pressure walbro in my 89. I did this for 2 reasons. One both pumps died in the same day and I'm going crazy on the engine. Go walbro or go home. :D
Jason Liss
1989 XR Still in pieces
1986 XR Sold!
SARON81
Post by SARON81 » Mon Nov 20, 2006 9:26 am
1lowscort wrote:my fuel pump is external or i would do the walbro 255..im now considering changing out for the later in tank fuel pump because ive been hearing nothing but bad things about external pumps.
Unless somebody replaced the stock setup you have two pumps. :banghead
There's no "early" and "late" pump either. They're all the same 85-89.
Frag
Post by Frag » Mon Nov 20, 2006 11:02 am
Yup.
1 in the tank to get it up and out. The 2nd to apply pressure and increase flow.
BTW if you wanted they do sell 255lph inline walbros, or you could go with a bosch setup like me but you will need custom adaptors to use the stock ford quick connect stuff.
xrian
Post by xrian » Mon Nov 20, 2006 3:26 pm
I believe he's talking about an Escort pump not the XR.
Ian G-J
Ontario, Canada
SARON81
Post by SARON81 » Mon Nov 20, 2006 3:42 pm
xrian wrote:I believe he's talking about an Escort pump not the XR.
:dunno
I assumed that since it was in the "XR" section... we were discussing an XR... but now that I re-read his original post... you may be correct. :roll:
1lowscort
Post by 1lowscort » Mon Nov 20, 2006 5:41 pm
yea im workin on an escort, i posted here because im asking a question about XR fuel pumps. although mine may be set up the same way as yours...not really positive, im going to have to figure it out.
1986 Escort GT
