High Test Gas or Regular?
Is the XR able to run on regular gas if it is tuned for it? Just as an every other day car would it be okay to de-tune it? Just by changing the dist. advance.
- Level 2
LOL! this is very true...However, boost being more addictive than cocaine, crack, crank, meth, sex...etc...well...it's not always practical.mikerobison wrote:You can run low octane fuel with the turbo is working order, and dist. in stock timing, just don't drive like a flippin maniac. Keep your right foot off the throttle and not buried into the floorboards.
I should develope and market....Boost-erette GUM....yeah...that's the ticket. Give's you the SENSATION of 20psi boost even while driving a Yaris.
- Level 6
If you drive, say, 10,000 miles a year, and you average, say, 20 mpg., and let's say for the sake of discussion that the difference in price between 87 octane and 93 octane is 26 cents a gallon, you'll save $130 a year.
Richard Curtis
...now, with the cost of fuel being so high so the difference in percentage of cost being so low...
enjoy the car.
run the premium fuel.
enjoy the car.
How much money do you think you will save over a year? If you have good driving habits, then this would not be a problem. To me. I dose not matter weather you have a honda or a merkur. Driving habit dictate gas consumtion. You can get up to 25 to 30 mpg with a good stock tuned XR. Well good luck on you work.
Jason Liss
1989 XR Still in pieces
1986 XR Sold!
1986 XR Sold!
- Level 4
I should develope and market....Boost-erette GUM....yeah...that's the ticket. Give's you the SENSATION of 20psi boost even while driving a Yaris.[/quote]
i am not addicted to the boost, i can quit any time i want to
jake nawrocki
1 cor 9:24
"if its not broke, i can problably still fix it"-tim allen
1 cor 9:24
i ran this experiment with my saab 900 turbo. i adjusted the stock boost controller all the way down to basic boost (5pai) and filled up with 87. it ran fine. i took it on a 200 mile highway trip. then the next day i filled up with 93 and cranked the boost up to about 18 or 19 psi. i took it on a 200 mile highway trip. after wards i calculated gas mileage and figured out cost per mile based on the mileage and cost of gas for each test. what i found was that on 87 with 5psi of boost, the car got such crappy gas mileage that it was actually MUCH cheaper to run at high boost with 93 octane gas.
so all of you that are thinking that you can turn the boost down and drive for cheap on 87 octane, you are just fooling yourselves. a turbo motor running basically in NA mode will make such little power that you will get much worse gas mileage.
ian the re-animator
