Comparison of the carriers (XR open differential left, GM LSD right). You might notice that the GM axle hole is ever so slightly smaller than the XR's, this the reason that I will have to have the stub axles turned down:
Here are pics of all the markings found on the GM carrier... not sure if any of these are significant to anybody:
Comparison of the ring gears (XR left, GM right). As you can see, both are 7.5" (I have heard rumors of some GM rings being 7.65"):
The only markings located on the GM ring gear... not sure if these are significant to anybody either.....
Look, no modification is required to bolt the XR ring gear to this GM carrier!!! The holes line up perfectly!!!
Shot of the carrier with the passenger side bearing race removed, which is required (in addition to grinding) to get the carrier into the XR's pumpkin. Due to the extra size of the LSD carrier it's impossible to turn it at the correct angle inside of the case in order to get it installed, so clearance must be made. I never understood the need for grinding until I attempted to install it 1st hand.
I don't have all the answers yet, as I am still gathering information and figuring out what I need to do to complete the project. It all lies within the spacers (might need one under the bearing race and under the ring gear also, but have not yet determined) and the stub axle machine work.
