LS2 in a XR4 Underway /Pics Update...
xr4outcast
Post by xr4outcast »
So are there any updates to this kick ass thread?
Rob Booth
grve66
Re: LS2 in a XR4 Underway /Pics Update...
Post by grve66 »
Updating this. Motor spun a rod bearing!!!! so now it is time for bigger better stronger... I am turning my 364c.i. motor into a 403 c.i. should be roughly around 450ftlb torue and 450 rwhp when done with mild cam..
rod knock video...
started pulling motor...
motor on the ground,,,
the shop that i do most my work at. it my friends Shop and I work there in the summers when My other Job is on hiatus.. only specialize in Newer German cars...
motor mounts they are basic but they work.. I would like to make something more prettier but maybe at a later date
steering rack tapped to accept An fitting with brass crush washers. I hated tho o-ring setup..
Image.
I will post more engine building pics soon..
I'm sure I speak for many when I wonder what caused this failure. :dunno
Sierra-Mk1-Christian
Post by Sierra-Mk1-Christian »
have you found at youtube , super LS2 XR4 project :headbang :headbang :headbang :headbang
http://www.youtube.com/watch?v=s8fqFHNfEBM
Christian
grve66
Post by grve66 »
A little update.. I have short block built.. :headbang . al the rest of the parts are here.. head gaskets, oil pump, lifters, new rear cover ,custom cam etc... will be posting pics over the weekend
grve66
Post by grve66 »
well getting closer.. got short block built and heads installed this weekend..
Post by Ray »
LIKE!
8)
LS2XR4 wrote:Motor spun a rod bearing!!!!
Now that you've torn things down, any evidence of what caused the failure? I recall that the engine was a low-mile unit, but was it a junkyard pull or some sort of warranty replacement? Just thinking it may have had a "pre-existing condition". :dunno
grve66
Post by grve66 »
bingo... i heard a little bearing wrap when cold and would go away after warmed up. That was my feeling.. as nothing was loose, broken main bearings were fine. just 2 rod bearings.. the motor had a little shake also when cold at around 1600-1900 rpm's..
But everything checks out good. and everything is new in the motor... New crank ,rods ,pistons,oil pump(high pressure),cam,push rods,front and rear main seals lifters,main and rod bearings, block hot tank and cleaned, heads checked and new valve stem seals and springs were installed..
so basically a new motor... :headbang :mrgreen:
onebad7up
Post by onebad7up »
Watching your progress makes me want to get back on my Merkur. Cant wait to see a vid once your car is running again...
grve66
Post by grve66 »
onebad7up wrote:Watching your progress makes me want to get back on my Merkur. Cant wait to see a vid once your car is running again...
Thanks. Is your car down? is was real nice the the 302 turbo.. Mine should be going this weekend... or maybe today.
grve66
Post by grve66 »
well she runs again... it pretty wild though..
http://www.youtube.com/watch?v=5mUDfAkg ... re=channel
It lives! :headbang :cheers
grve66
Post by grve66 »
merkurdriver wrote:It lives! :headbang :cheers
yes it does. :cheers .
have you received the Red car yet?
well I started on making the back seats a little more "bucket like" they will be re-covered in BMW terra cotta with black stitching
LS2XR4 wrote:well she runs again... it pretty wild though..
:headbang ...even if Youtube does a horrible job a reproducing engine music.
