LS2 in a XR4 Underway /Pics Update...
Re: LS2 in a XR4 Underway /Pics Update...
Post by merkurdriver » Fri Feb 24, 2012 4:40 pm
LS2XR4 wrote:
have you received the Red car yet?
Yes, its here in sunny Ohio now.
LS2XR4
Post by LS2XR4 » Sun Feb 26, 2012 3:10 pm
well got the seats test fitted as most of the work was done without the car being present.
this picture I need to finish the bolster.
bolster started on drivers side
pics of the gap that need to be filled
drivers side gap
whitelx
Post by whitelx » Sun Feb 26, 2012 3:28 pm
where are you getting the foam and are you using a spray adhesive to attach it? How are you cutting/finishing the foam? I have always been curious about seat building.
LS2XR4
Post by LS2XR4 » Mon Feb 27, 2012 2:25 pm
You can get the stuff from http://www.miamicorp.com/
I have a friend that did it with my direction.
I have found lots of youtub-e video showing how to cut the foam. mainly you can use a electric cutting knife( think turkey) and a spray adhesive.. it much easier than you would think. the hard part is making it symetrical..
LS2XR4
Post by LS2XR4 » Mon Oct 14, 2013 12:47 am
I miss my car.. :frown getting that itch and still have crossmember but don't have the space right now to build another
Post by Esteban » Mon Oct 14, 2013 12:54 am
Coyote motor Brett!
whitelx
Post by whitelx » Mon Oct 14, 2013 1:14 am
wish it wasn't damn near impossible to get one of the 5.3L truck engines through the referee.
nathankershaw
Post by nathankershaw » Mon Oct 14, 2013 2:00 am
Who knows as my mind seems to change from one second to the next, but buying a LS/T56 2000-ish? onwards Camaro or Firebird seems to be the way to go for a CA V8 swap.
The stable is empty...
LS2XR4
Post by LS2XR4 » Mon Oct 14, 2013 3:23 am
whitelx wrote:wish it wasn't damn near impossible to get one of the 5.3L truck engines through the referee.
I agree. if I could just do a truck motor it would make the swap so much easier and tons cheaper. of course it would have to have a turbo on it.
technically the light duty truck motors were also able to pass smog as long in a car as long as it had the smog equipment. according to CA bar rules.
Post by Mike McCreight » Mon Oct 14, 2013 9:02 am
LS2XR4 wrote:I miss my car.. :frown getting that itch and still have crossmember but don't have the space right now to build another
I miss your car too....
nathankershaw
Post by nathankershaw » Mon Oct 14, 2013 4:59 pm
It's funny. After I sold my last car I looked around for projects that would be a easier ie. PRE-SMOG but nothing really scratched the itch that the XR does.
Unique engine
Unique body
Good to drive out of the box
RWD.
It ticks a lot of boxes.
XR4Tim
Post by XR4Tim » Wed Dec 11, 2013 2:39 pm
That crossmember will work with L33's, right?
Tim Bevan - OEM Part Haus
'85 XR4Ti - '97 E36 BMW - '86 LS1 951 - '63 Midget - '09 MINI - '12 Outback - '99 Discovery II - '02 S2000
slo_ryd
Post by slo_ryd » Wed Dec 11, 2013 8:50 pm
Tim it should work with an L33, in my research the mounting points are the same on all the ls blocks.
XR4Tim
Post by XR4Tim » Fri Dec 13, 2013 6:24 pm
That's what I figured.
I've cleared room in my budget to get one.
Longitudinal
Post by Longitudinal » Sat Nov 25, 2017 11:32 pm
I'm beginning to read this thread. It's a damned shame that Photobucket is what it is now. Pics don't load, but an endless stream of ads does.
