Page 1 of 7
Let see pic's of your XR with killer wheels
Posted: Fri Apr 30, 2010 10:03 pm
by Ralphs Rapid Transit
Post pictures of your XR with aftermarket wheels you chose for your XR. Don't forget to add tire and wheelsize.
I need help picking out a new set if wheels for my XR. I ordered a set of 16x7.5 and they hit the strut, offset was way off. Back to the drawing board.
Show me what works on your XR
Posted: Sat May 01, 2010 12:17 am
by xrattiracer
theres a huge thread about this on merkursport already, its worth checking out.
I got some 17x7 40ET wheels off craigslist, not sure what manufacturer. they fit just fine on a stock setup.
http://www.flickr.com/photos/29953206@N03/4553324202/
Posted: Sat May 01, 2010 7:59 am
by Mike McCreight
If you like the rims, go with (gulp) spacers. MC2 can supply the ARP studs.
We have an odd offset. Focus rims are usually too high an ofset, RWD too low.
17x7.5 Mullins (Australia) w/205-50 BFG KD (measure out at quite a bit larger than typical 205-50-17) Took a bit of work to get these in. Spring perch and fender lip mods required. These wheels will return with 235 and 215-40s.
TSW Hockenheim R 16x7.5 with 225-45-16. Offset isn't marked on these, they're Sierra specific. No centering rings. They really did their homework, NO issues with a stock suspension car. I'd never seen a 225 up front without mods before.
Posted: Sat May 01, 2010 10:27 am
by NiggyMerk
These are Ford Racing Cobra R's 17x8 cut down to a 21mm offset. Fronts are 225/45s and rears are 245/40s. They all rub a little over big bumps even with fenders rolled. Might go with 215 front and 225 rear next set.
Posted: Sat May 01, 2010 11:08 am
by Longitudinal
Mike,
Where did you get the Hock-Rs, and how much did you pay?
Posted: Sat May 01, 2010 4:12 pm
by xr4ti41028
Longitudinal wrote:Mike,
good luck finding some tsw doesnt make them and they are harder then hell to find been looking for over 3 years now :cry:
xr4ti wheels
Posted: Sat May 01, 2010 9:42 pm
by lscmark
Primax 772 17 x7 with 215/45/17 tires.had to grind about 1/4" from outside edge of front coil spring seats,otherwise,great fit/handling.
Mark
Posted: Sun May 02, 2010 1:31 pm
very nice! Let's see more, Please...
Posted: Sun May 02, 2010 5:42 pm
by hEaT
BSA 333's, 17x7 +40mm offset with 215/45/17 Dunlop Direzza Z-1 Star Specs. Factory studs, no spacers, coilover conversion in the front.
Posted: Sun May 02, 2010 8:03 pm
by leesonic
Focus wheels are easy, 25mm spacers on the back, 15mm on the front.
Capri 6x13s only fit on the back. Now 7x13s are a different story...
Posted: Mon May 03, 2010 7:03 pm
by KingpinCEO
235 40-17 in front
275 40-17 in back
same cobra R replica wheels as posted a few posts up.
Posted: Wed May 05, 2010 10:53 pm
All those XR's are ImageSEXY!!!! Keep them coming....
Posted: Thu May 06, 2010 7:20 am
by Ray
Pony wheels painted white in 225/50/16 RT615s
Motegi MR3's 17x7 with 13mm front and 15mm rear spacer (ET was 42mm on these wheels) wrapped in 225/45/17 kumho V710
17x9 ET20 mustang cobra replicas wrapped in 275/40/17 kumho v710
Am looking for a cheap set of 17x8's ET20-30 if anyone has any!
Posted: Thu May 06, 2010 1:23 pm
by nathankershaw
What wheels and specs are they on the black one?
They look great!
Posted: Thu May 06, 2010 6:23 pm
nathankershaw wrote:Ralphs Rapid Transit
They look great!
The wheel and tire package is. Elbrus IO5 17x7.5 41MM offset, with 205 45-17 up front and 225-45-17 in the rear. Best thing is they don't rub
