20+years later..Keeps going&going&going..get the picture
nzwinrz
Re: 20+years later..Keeps going&going&going..get the picture
Post by nzwinrz »
Some idle time...lots of back ground noise picked up with cell phone..better in person
[video=youtube_share;5AkEqZGmSng]http://youtu.be/5AkEqZGmSng[/video]
[video]http://s714.photobucket.com/user/nzwinr ... 1.mp4.html[/video]
nzwinrz
Post by nzwinrz »
I had to remove the FRS fuel pressure regulator(2.7bar) and the adj. after market one I bought to use. The FRS had too low OP pressure. The latter had to much pressure spread 1.3bar from vacuum(2.0-3.3)) to with out. Research showed me its got a 1.7ratio instead of 1.1 needed. End resolution was to install the stock and adj to 3bar with vac and 3.5 without...5bar spread
nzwinrz
Post by nzwinrz »
Got the strut support made...
Post by Ray »
You are an inspiration.
nzwinrz
Post by nzwinrz »
Well let me go back and catch up on coulpe weeks work....
Got the new/used dash installed, carpet, front seats, console....
nzwinrz
Post by nzwinrz »
Been getting all hole welded up and smoothed out...
nzwinrz
Post by nzwinrz »
No rear seat or trim yet, waiting till after paint so to install new seals and glass....
front windshield held in with duct tape :), sitting on the inner rubber trim molding, till after paint work done
New door seals coming from Argentina, for now used passanger seal and rag for drivers side to keep from banging the newly painted jams
nzwinrz
Post by nzwinrz »
Cleaning out the stable, some work in progress....
Birds eye view before bombing...
Can't leave out the back side...
nathankershaw
Post by nathankershaw »
Wow!
What a stable!
What's the story on the Spitfire?
What's under the hood the you need to remove air from the rad in such beautifully crafted dramatic fashion?
I think I've seen your Focus build on Passionford. US to UK conversion?
nzwinrz
Post by nzwinrz »
Original engine from '86 > '05 289 Hilborn Injected
You can see my first XR in driveway, bought brand new in Dec 1985
and the one now..FORD 347 Stroker
nathankershaw
Holy $#!%.
Small block in Spitfire. Wow!
Whats been done to the chassis?
nzwinrz
Post by nzwinrz »
New frame from motor mount rearward to clear Lakewood bell housing, 5 link rear suspension, toploader 4speed, narrowed 8" with Auburn unit
Front suspension modified using GT6/TR6 components, headers and side exhaust I made. Well all mods but the paint...did most between '84-86'....engine upgrade in '05 along with new input, main and cluster shaft in trans, new Auburn to diff, and added 3" to each side of diff assembly, went from 15x10 to 15x7 wheels
nzwinrz
Post by nzwinrz »
Been heck of a Winter, ice storm dropped some very large branches from my beautiful tree(lots of shade from the Texas heat)
Got the Kia, but missed the Focus(glad I didn't park on that side of dr) Kia got full coverage, Focus not-so
Nice to wake up seeing this once I opened garage door
Back door
Clean up work that day
Got wood for next yr
nzwinrz
Post by nzwinrz »
Got the doors back on, for couple months there was no glass, regulator, guides, trim or latches. Just what I needed to drive around. Later in Feb I refreshed the regulators, cleaned/re-greased, guides and rollers, locks/latches, removed old wrappings from harness and rewrapped, installed new oem felts around the inside perimeter of glass. Haven't bought the sound dampening mat yet that will darn the inside of doors, inner door panel and quarters panels. Plan on adding small fiberglass layer on the insides of plastic interior panels to reinforce them from future breakage.
I'm working with the idea of giving it the Sierra look, at least from a distance or as I blast by.
Going to be giving it some time to Love-it or Hate-it till I get ready to do finial paint. Considered gloss black to better blend in with reflective side glass.
Next time you step back and look at the side of you're XR, visualize the door glass flipped around, it is very close to the Sierra rear quarter glass, with some work the glass could be made to fit with in the quarter. If I could get the oem glass for it, it'd already be done. Still would have to deal with the trim, but I'm sure something could be found to suffice..
MercMike
Post by MercMike »
I now have much more respect for KIA's. :cheers
'85 XR
