Project Bronze Turd
turboplz
Project Bronze Turd
Post by turboplz »
Just realized I never started a build thread here for my 89 xr. I'm just going to copy and paste some things from merkursport to get caught up, but mostly just pics:)
So this is the 89 Xr I picked up from Merkd ya. I haven't picked a name out for her yet, she hasn't quite earned that, so she is currently dubbed, bronze turd.
This is how the engine bay looked the night I got her home:
I don't have any current pics of the engine bay, but the only things left in it are the block and wiring. I'm figuring out how I want to go about tucking the wires, but my plan is to have a very clean engine bay, battery relocated to the trunk, etc. On the engine front, I'm currently porting and polishing my head and intake manifolds. The intake I'm going porting into a split runner setup, paring 1&4 together as well as 2&3. This helps to maintain more low end response as well as giving you better top end. Once I get a new metal blade, I'm going to cut the upper in half and remove the "webbing" between 1&4 (and 2&3) to give each pairing more "plenum."
The head is actually crack free and relatively clean. I'm about 90% done with cylinder #1 ports, bowls and chamber, just need to go back through and make a few touches with a smaller bit. I've learned a lot from past head porting and I really feel that I'm going to yield great results (it also really helps having some detailed picture of a stage 3 boport head, lol). I'm going to keep the stock valves, but the stock cam is toast. Undecided on a cam yet, but I'll probably end up with a bo 1.9.
I've got an e6 that I absolutely ported the snot out of a couple months back. I really don't know if anyone has ever ported one to this extent, I'll try and snap some quality pictures at some point. I compared it to the stock e6 I pulled off the car and it's night and day between the two.
The turbo is a .48 turbine a/r, which will actually be perfect for the street, though at some point I'll probably step up to a 50 trim and eventually a cossie turbine.
I am still in the process of figuring out what intercooler setup I'm going to go with. Since I'm going with a split runner manifold, I have to keep the upper pointed in the stock direction(though I might be able to do a 90, not sure yet). I'm thinking of an intercooler with the inlet/outlet on the same side to keep piping to a minimum, but we'll see about that.
For transmission, I have an 86 SVO t5 that I'm currently rebuilding, turns out it needs a mainshaft so that is going to delay me for a little bit. I already have a pyropete clutch setup, manual pedal assembly and most of the odds needed to convert to a manual trans. Just need to figure out what I'm going to do for the driveshaft. Rear end is an auto gear, I'll probably keep that and do the LSD route for now with plans to go with a supra rear down the road.
What I got the car, I started inspecting it for rust, turns out the pinch seams are in near perfect condition! There is one rust through at the spare tire floor pan, only reason I figured that out is because there is no gas tank on this car, lol. No worries there, however, Olson (merkdya) is going to hook me up. The suspension is shot, so a full mc2 setup is in store, cossie bars, coilovers and all. Not sure what I plan to do about wheels quite yet, but the wire mesh rims will have to go, they just can't handle a fat enough tire!
Finally, here is the interior:
Pretty much trashed, at some point it appears a family of mice or squirrels made it their home. But that's to be expected from a car that most likely hasn't run since 2000! I'm not sure what I want to do yet on the interior. I want to be able to let the kids ride in the car, so a back seat is a must which most likely rules out any racing seats. Most likely I'll swap over to a black interior if I can find one in good enough shape.
I definitely have bigger, future plans for the car. But for now, I just want to get her running and driving again. The bigger plans will have to wait until further down the road!
Jason
2014 Focus ST
turboplz
Re: Project Bronze Turd
Post by turboplz »
Pics of ported e6
Intake manifolds, paired intake runners with a partially gutted upper. These aren't finished in the pictures, I'm done with perfecting all mating surfaces and smoothing, just need to get it welded and open the upper for a larger TB.
I have ported the head as well, but I don't have any quality pictures of it. When I get it back from the shop for the valve job, I will post pics up then.
Jason
2014 Focus ST
turboplz
Post by turboplz »
Uh ohhhh!!
Fixing it...
All better(I have since painted it)!!
Jason
2014 Focus ST
turboplz
Post by turboplz »
Hi-flow 3" downpipe
Refinished nasty valve cover and brake booster
Jason
2014 Focus ST
turboplz
Post by turboplz »
Finally, where I'm at after finishing up today :)
Jason
2014 Focus ST
In XS 7
Post by In XS 7 »
Very nice job,keep the updates coming. :cheers
turboplz
Post by turboplz »
Transition from Bronze Turd has begun!
Jason
2014 Focus ST
Post by Ray »
What bits are you using for hogging out the manifold?
I am digging the progress. :mrgreen:
turboplz
Post by turboplz »
Thanks!
I just used the harbor freight cheapo grinding bits. It took a while, but I'm just too cheap to spend the money on quality bits, lol.
Jason
2014 Focus ST
turboplz
Post by turboplz »
Haven't really updated this in a while, but here's a few more pics of how it looks right now. The quality isn't great in the pics, just cell phone shots.
**This first picture is before I decided on the changes you see in the last pic**
Jason
2014 Focus ST
catapultkid
Post by catapultkid »
Looks nice man. I know body work can take forever. Looking forward to see where you end up running all those wires and vacuum lines in the bay.
-Paul
'85 Merkur XR4Ti
K20, VW mk2
'89 K2500, 6.0 swap
'00 Honda Insight
turboplz
Post by turboplz »
Here's how she stands today. Haven't done a lot, but the past couple days I've wet sanded like a mad man, lol.
Jason
2014 Focus ST
In XS 7
Post by In XS 7 »
Cool, nice job :thumb
MercMike
Post by MercMike »
I don't know where you got it.
But that's a fine bottle a turd polish your using there :headbang
'85 XR
