XRBrati Underway....
Not very exciting, but I finally got around to getting the last of the holes through the bed sealed off. All shots of the driver side.
Before...
Filler plates cut and located in place...
Filler plates bonded in place...
Same area as viewed from the other side...
Speaking of "the other side", here's a shot of the completed passenger side...
Starting out on my new career as a flower delivery-man... :mrgreen:
Post by Ray »
I am happy your wife is as tolerant as mine.
Okay, finally got around to getting the rear of the bed attached to the main body. First, clip off the useless sheet metal...
High-tech method for holding square tube in place for bonding...
Ugly, but functional... (it all be mostly hidden any way)
Some custom pieces cut for the corners out of galvanized angle, opened up to about 110 degrees with the press...
And the even more high-tech way I held these in place...
Yum, yum, blue glue... :lol: (Loctite H8600 Structural Adhesive)
And just tonight, finally got some rust encapsulator/primer (http://nomorerust.com/) on the roll cage and bare metal in the bed...
grve66
Post by grve66 »
nice. did not know you had some welding skillz.. LOL
looks like a fun project.
xr4outcast
Post by xr4outcast »
Keep up the good work. :D
LS2XR4 wrote:nice. did not know you had some welding skillz.. LOL
For the most part, I don't. The cage fabrication was totally out-sourced - if you go back to page 18 you can follow along and see that portion being completed. Most everything else is bonded in place - a few exceptions here and there where the spot welder got used.
CV12Steve
Post by CV12Steve »
Brad, you need one of these!
This one is a little less "busy".
Stephen
CV12Steve
Post by CV12Steve »
Here's a Sierra-based pickup that's not a P100.
Stephen
CV12Steve wrote:Here's a Sierra-based pickup that's not a P100.
I see you've been spending some time on UK eBay lately Steve! :lol:
This conversion looks really well done. It also helps that a 4-door was used as the donor, for both aesthetic and function reasons. If I was to do it all again :beats head I'd use a Scorpio.
Interesting bull bars too - I didn't know there were several different types. Wonder if they'd bolt-on to the US cars just as easily as the Euro?
CV12Steve
Post by CV12Steve »
The mounts on the second bar seem to extend much higher than on the first. The headlight openings are also shaped differently. It's possible one may be for a Mk I and the other for a Mk II, though neither specifies.
I would expect some moding/fabing to the mounts being required due to front end sheet differences because of 5mph bumpers.
You'd probably also have to fit a Euro bumper cover (most likely not a Cossie), obviously with less concern about the lack of crash protection underneath. Maybe a 4x4 front cover? It would be good to see something a little different (that is before someone gets overwhelmed with that amazing backside (any thought of naming it J-lo? It is all about the bum)).
Stephen
Subaru Outback rear bumper and cover in place....
See related post in General section, Photoshop my Ride
Raze
Post by Raze »
Damn that's hot...
HY35w, FMIC & BOV, 3" exhaust, 75#/hr, 255lph, MegaSquirt-I V3 w/3bar, T5, 4-point roll bar, rear strut brace, gutted, lexan windows and sunroof, Odyssey PC680, Koni + Ground Control (7" 250#/in) front, KYB (8.5" 600#/in) rear, TC rear brakes
Raze wrote:Damn that's hot...
Thanks Paris. :lol:
xr4outcast
Hurry up and give me your money so I can finish that dam thing. Your time is up!! You need to start another, not so ambitious project that you can finish in less than a year. :thumb
I think you need to take an early morning road trip Saturday and hang out in VA/MD.
By the way its really starting to take shape.
