Custom turbo heat shield
99 Subaru Legacy gt wagon
69 VW bug
88 Merkur Xr4ti
Meow
69 VW bug
88 Merkur Xr4ti
Meow
Re: Custom turbo heat shield
Even better if it were made out of your personalized vanity plate...
How is it mounted to eliminate vibrations?
It's not fully mounted yet, but I'm going to use a L bracket to the unused bolt hole next to the oil tube and probly some steel wool or brillio pad in between to reduce vibration.
69 VW bug
88 Merkur Xr4ti
Meow
69 VW bug
88 Merkur Xr4ti
Meow
Be careful steel wool will catch on fire very easy.
I remember seeing a picture of a stainless steel mixing bowl, like you would find in any kitchen, that had been fashioned into one really good looking heat shield. I believe it was on this website. Anyone else know what i'm talking about?
Yeah we've seen it.
Hey Esteban can you post the link or more info about it? please.Esteban wrote:Yeah we've seen it.
Colin's photo links no longer work but this is his thread on his heat shield:
viewtopic.php?t=8060&highlight=walmart
Thank you Ed, it is a shame that the photo links don't work. I will try to elaborate a turbo shield based on this idea, so, I will attack my wife's kitchen to see if I find something that will work ( I will buy a replacement before I dare to cut and weld any of my wife's hardware just to be safe ).
- Level 1
That is a sweet idea!
I have old plates, so i'll play around with this when I get home from school in april.
Connor
'89 XR 254000 miles. Stock (until spring, then poor college student mods begin)
'99 Audi B5 A4 2.8 v6 (Technically my dad's, but he doesn't drive it)
Since I'm a Noob, i'll put an apology for dumb questions down here. I'm 19 and completely self-taught
- Level 1
You guys might have seen this already, it uses the same mixing bowl concept you guys talked about. http://www.supraforums.com/forum/showth ... ics/326366
-Conner
I'm still waiting for the paint to burn off of mine. So You should consider either burning/stripping it prior to installation, or using another insulating material inside of it. The plate by itself lowers the temp surrounding the turbine about 200 degrees. I'm sure Mr.supra's S/S shield works better but mine turns heads.boost_is_fun wrote:That is a sweet idea!
69 VW bug
88 Merkur Xr4ti
Meow
69 VW bug
88 Merkur Xr4ti
Meow
- andyofcolumbusmerkur
I think that is cool. Thanks for posting it.
