My Merkur XR4Ti Project
rcbooth
Post by rcbooth » Fri Feb 02, 2018 6:32 pm
Although it is now in winter storage I thought I'd post a few pictures of my 1986 XR as delivered (eBay) last year and the first bits of changes and improvements that I'd done last summer. While completely rust free, the dash was a mess with extensive cracking. I bought a good dash pad from Midwest Merkur and replaced the original. At the same time I replaced the instruments with a mix of later US (speedometer) and Sierra. I also replaced the "information Center" with boost, volts, and oil pressure guages.The seats were pretty shabby and I replaced the front with Porsche Cayman seats. Eventually I will have the rear seats recovered to match. Yet to install are a complete set of Raven interior trim (also from Midwest Merkur) to match the Raven dash. Finally, I've replaced the 14" wheels with 15 x 6.5 Contour wheels with 205-50 x 15 tires. A link to photos of the car and changes is here:
http://rcbooth.zenfolio.com/p141607041
Once the weather warms up (it is 12 F today) I have a 1994 Mustang V6 T5 (need to shorten and turn down the input shaft) to install. The pedal assembly is already in place as it was done when I had the dash all apart.
RCB
Re: My Merkur XR4Ti Project
Post by merkurdriver » Tue Feb 06, 2018 1:39 pm
Cayman seats look good in there...clean car :cheers
rcbooth
Post by rcbooth » Tue Feb 06, 2018 7:37 pm
Thanks! Biggest effort was drilling out the rivets holding the original mounts to the seat adjusters.
RCB
cmouta
Post by cmouta » Fri Feb 09, 2018 9:57 am
Those contour wheels look sharp on there! Are they really 15x6.5? I was always partial to the 15" 7 spoke "diamond cut" 95-97 SE wheel
2013 Nero Fiat 500C Abarth
1988 Mono Rosso Red Merkur XR4Ti
1974 VW Thing
2006 Bajaj Chetak 4T w/ sidecar
rcbooth
Post by rcbooth » Fri Feb 09, 2018 10:13 am
They are, indeed 6.5" wide. I measured them. They were in good condition and cheap so it seemed like a good approach for a mild upgrade. RCB
JacquesC
Post by JacquesC » Sun Feb 11, 2018 11:49 am
I agree, you get decent bang for the buck with those. I love you car btw, rcbooth. It looks so clean like that in white.
ckanani
Post by ckanani » Wed Mar 21, 2018 10:33 pm
Beautiful car!
Charles
markley007
Post by markley007 » Wed Apr 18, 2018 10:14 am
What kind of paint did you use to paint the dash with and what was your process?
Can't be a pimp and a prostitute too.
Sean
rcbooth
Post by rcbooth » Wed Apr 18, 2018 9:41 pm
The dash isn’t painted. I replaced the original with a later raven dash in good condition. The lower dash is painted though. I used an automotive paint for plastic / vinyl. I just washed it thoroughly and quickly wiped it down with a solvent.
morlynon
Post by morlynon » Thu May 17, 2018 4:26 am
Nice car! I recommend SEM paint for the interior pieces.
rcbooth
Post by rcbooth » Thu May 17, 2018 10:40 am
Thanks. I've been using SEM for the plastic and vinyl painting. They have a wide selection of colors although Raven is tough to match.
