2.3L Fastener Torque Values <& Header bolt source>
Post by DPDISXR4Ti » Fri Oct 19, 2007 5:52 pm
As pulled from the Automotive Component Engineering Site (http://www.powerbyace.com), who happens to be a niche supplier for some neat 2.3 engine parts. Go to their "Technical" section for the list below and some other useful stuff. I'm planning on getting a set of their low-clearance header bolts - pretty neat to be able to have the head size less than the bolt itself!
Ford 2300 SOHC
Engine torque specifications
All are in LB/FT, unless noted.
Auxiliary shaft gear bolt M10 28-40
Auxiliary shaft thrust plate bolts M6 6-9
Auxiliary shaft cover bolts M6 6-9
Belt tensioner pivot bolt M10 28-40
Belt tensioner adjustment bolt M8 14-21
Camshaft gear bolt M12 50-71
Camshaft thrust plate M6 6-9
Carburetor bolts M8 10-14
Carburetor adapter bolts M8 14-21
Connecting Rod bolts (stock) M9 30-36
Crankshaft dampener bolt M14 100-120
Crankshaft front cover bolt M6 6-9
Cylinder head bolt M12 80-90 (1)
Distributor clamp bolt M14 14-21
Exhaust manifold to head M10 16-23 (2)
Flywheel to crankshaft M10 54-64
Fuel pump to block M8 14-21
Intake manifold to head bolts M8 14-21 (3)
Main bearing cap bolts M12 80-90 (1)
Oil pump pickup tube to oil pump M8 14-21
Oil pump to block M8 14-21
Oil pan drain plug M14 15-25
Oil pan to block bolts M6 6-8
Oil pan to block bolts M8 8-10
Oil filter insert to block ---- 20-25
Rocker arm cover bolts M6 4-7
Spark plugs M14 5-10
Water pump to block M8 14-21
Water outlet to head bolts M8 14-21
(1) Tighten in three steps. 30 LB/FT, 60 LB/FT, 90 LB/FT
(2) Tighten in sequence two steps, 8-10 LB/FT, 16-23 LB/FT
(3) Tighten in sequence, two steps, 7-9 LB/FT, 14-21 LB/FT
BeefFajitas
Post by BeefFajitas » Sat Oct 20, 2007 9:00 am
That baby freaks me out.
-Nate
Frag
Post by Frag » Sat Oct 20, 2007 2:08 pm
BeefFajitas wrote:That baby freaks me out.
WTF!!?!?
They are only a decade or so behind ally mcbeal... remember that stupid ass dancing baby?
xr steve
Post by xr steve » Wed Oct 24, 2007 8:22 pm
are these specs right cus i am just bout to put my motor back to gether.
87 xr4ti
2001 GTP
Post by DPDISXR4Ti » Thu Oct 25, 2007 10:15 am
xr steve wrote:are these specs right cus i am just bout to put my motor back to gether.
I can't tell you I've verified every one, but they look generally correct to me.
Post by Ray » Sun Feb 28, 2010 11:39 am
Bump. Please move this to the FAQ section.
Post by DPDISXR4Ti » Sun Feb 28, 2010 11:45 am
demonfire wrote:Bump. Please move this to the FAQ section.
So demanding... :lol:
Slinky
Post by Slinky » Sun Feb 28, 2010 6:49 pm
In the Ford Specifications 1988 Car for the 2.3 turbo, the only differences I could find were:
Main Bearing Cap Bolt 75-85
Oil Pan to block 10-13.5
Exhaust manifold to head 20-30
Add:
Turbo Nut to Manifold 28-40
I just thought those critical components were worth noting *shrug*
There was a few others that were 1 or 2lb-ft difference but nothing spectacular.
But I would always consult the proper year's service manual for confirmation :D
-Will
Re: 2.3L Fastener Torque Values <& Header bolt source>
Post by milehighXR » Sat Oct 12, 2019 11:00 am
How about a length for those bolts? Specifically the length of crank to flywheel, and the clutch to flywheel.
