valve cover gasket
SVT Driver627
valve cover gasket
Post by SVT Driver627 » Fri May 06, 2005 12:12 am
i tried searching but came up empty handed...
The previous owner recently put in a cork gasket for the valve cover but it seems to be laeking, the gasket only has about 40 miles on it so should i replace it with a rubber one or remove the cover and try to reseat it properly. thanks in advance.
also where can i get gaskets or what not for a fair price?
~Alex
2000 SVT Contour
For Sale:
KD-AR5000 JVC HU
18" RS5's with tires
2 dish recievers
Local only please
turboxr
Post by turboxr » Fri May 06, 2005 12:15 am
O'Reilley's or Autozone should have a blue Felpro job- many peeps have had probs with slight leakage, but i've not had any problems. You can also go buck wild and opt for a 93(?) to 95(?) ranger 2.3 gasket which has metal inbeaded for a better seal.
Someone help me out with more specifics....Ian, you there?
Chuck W
Post by Chuck W » Fri May 06, 2005 12:25 am
Throw the cork one away...far, far away.....
Go to a Ford dealer and get this gasket...
F57Z-6584-A
The last valve cover gasket you will ever need.....
SVT Driver627
Post by SVT Driver627 » Fri May 06, 2005 12:29 am
Chuck W wrote:Throw the cork one away...far, far away.....
F57Z-6584-A
what's it for/ est. cost?
~Alex
2000 SVT Contour
For Sale:
KD-AR5000 JVC HU
2 dish recievers
Local only please
rat_n_a_cage
Post by rat_n_a_cage » Fri May 06, 2005 1:43 am
F57Z-6584-A
I paid about $30 if I remember correctly. Haven't had a single drop of oil leak since. It's the only choice as far as I'm concerned.
Post by John Brennan » Fri May 06, 2005 2:32 am
Let me add my full agreement to Chuck and Rat-- with personal experience. Once you have it in your hands, you'll grok in fulness.
xrian
Post by xrian » Fri May 06, 2005 6:48 am
I also strongly agree with the other to use the new Ford Ranger gasket. It can be used over and over. The Felpro can & has caused many leaks and fires due the poor design. This was the gasket that Ford used to sell until they came up with a better design.
Ian G-J
Ontario, Canada
Cozz
Post by Cozz » Fri May 06, 2005 8:05 am
There is nothing wrong with the Felpro gasket. The problem is the valve cover. Felpro's have a groove on the center of the gasket that points upwards. XR's don't have this channel on the cover thus it's not meant for XR valve covers.
Work with me people. 8)
60-1, ATR manifold, modded Conquest IC, 3.5" custom upper, fully gutted lower, Crower rods with all the goodies, Dimond ash strays, 3" exhuast, 30 PSI+ baby!
xrian
Post by xrian » Fri May 06, 2005 8:27 am
All I'm gona say is keep a fully charged fire extinguisher with you at all times then.
Why use an known inferior gasket when there is a way better one available?
Ian G-J
Ontario, Canada
turbopower
Post by turbopower » Fri May 06, 2005 9:30 am
ditto w/ using dealer gasket, there about $35 in texas.
don't know why but the gasket and felpro seem to not work out in the long run.
i would stick w/ dealer brand myself :D
`john
88' XR, 86' SVO, 86' Cosworth
Chuck W
Post by Chuck W » Fri May 06, 2005 9:35 am
Don't let the cost scare you away....I've had mine apart so many times it has paid for itself a long time ago.
There is no muss and little fuss (the front portion over the cam tower can be tedious at times if the gasket has been stored for a while and has taken a set). the rest of the gasket has a full steel core (not little grommets at the bolt holes).
I've got one on each of the 3 2.3T's I have running right now...no leaks.
Factory application...95 Ranger 2.3....
xrpat
Post by xrpat » Fri May 06, 2005 9:43 am
I have used the re-useable rubber gasket but it has always leaked a little(sometimes a lot) torqueing the bolts carefully never helped either. After the last rubber gasket failed in a big way all I had on hand was a leftover sh!ty, cork gasket ( I just couldn't see spending $30 on 1 gasket that might not even work)so I lovingly installed it, adhearing it first to the clean v/c with permatex gasket dope then lowering it onto the clean head mating surfaces followed by carfull torquing down the bolts (these aren't head bolts now). I know its a piece of crap but it has worked flawlessly for a bout a year now. I agree with cozz the felpro rubber units are not designed to work with our v/c.
quirkymerk
Post by quirkymerk » Fri May 06, 2005 9:55 am
thanks for all the info. people I have been meaning to replace mine since it is leaking also.
'87 auto xr4ti sti wannabee going to Carlisle 2010!)
'90 5.0 LX stang
*Sarah*
SVT Driver627
Post by SVT Driver627 » Fri May 06, 2005 12:48 pm
Alright thanks everyone, so a 95 ranger gasket it is then, right?
Also will i need to use any kind of other sealer on the gasket or just put it on dry?
~Alex
2000 SVT Contour
For Sale:
KD-AR5000 JVC HU
2 dish recievers
Local only please
MerkXRTurbo
Post by MerkXRTurbo » Fri May 06, 2005 12:51 pm
Always seal the hell out of Merkur VC gaskets. It can't hurt, and will likely save you time later.
