The Official "What Does it Weigh" Thread
If you weigh something, post the results here. I (we) would appreciate a reasonably scientific approach to your measurements. In other words, don't post that a wheel weighs xxx pounds, but there is a tire attached. If you do measure it like that, also specify that there is a tire on it, what size the tire is and maybe even the brand and model.
What I'll do, as I have time, is condense all the data that you provide into a single post, categorized if/as necessary, that way you don't have to hunt for data. Would anybody really be looking for this information besides me?
So, that's the purpose of this thread. Now I'll kick off the thread officially by making the first post containing data.
www.mc2racing.com
www.mc2racing.com
Exterior parts:
stock XR4Ti front bumper cover - 11 lbs
genuine Cosworth RS front bumper cover (with stock metal support) - 17 lbs
XR4Ti stock metal front bumper with impact absorbers, driving lights and turn signals - 27 lbs
genuine Cosworth RS rear spoiler - 18 lbs
MC Rally Cosworth RS500 rear spoiler - 14 lbs
85 XR4Ti bi-plane spoiler (no 3rd brake light) - 12 lbs
86-87 XR4Ti bi-plane spoiler (with the 3rd brake light installed) - 12.5 lbs
North American-spec XR4Ti hood (without sound deadening liner, with emissions control sticker holder and latch) - 34.5 lbs
European-spec XR4i hood (with only the latch) - 30.0 lbs
Intercoolers:
Rapido intercooler core (bar and plate) - 10 lbs
Pace RS500 intercooler core (tube and fin) - 9.5 lbs
Forge RS500 intercooler core (bar and plate) - 22.5 lbs
Engine:
Oyler radiator - 19.5 lbs
stock D-port head, no valvetrain components - 58 lbs
Driveline:
T9 transmission, with fluid, release bearing, fork - 80 lbs (Gene Young)
T5 transmission, with fluid, release bearing, fork - 87 lbs (Gene Young)
Electrical:
Group 41 battery (typical XR replacement) - 32 lbs
Interior parts:
Sound deadening mat (tar mat under the carpet):
rearmost portion (rear footwell area) while slightly damp - 14 lbs
under front seats - 10 lbs
rear seat weight data (cloth seat material):
40% seatback (upright portion) - 8.65 lbs
60% seatback (upright portion) - 19.54 lbs
40% seat bottom - 8 lbs (Anesi)
60% seat bottom - 12.5 lbs (Anesi)
seat fold down release mechanism - 0.78 lbs per side
rear seat 'side bolsters' - 1.90 lbs per side
center seatback pivot bracket - 1.71 lbs
Suspension parts:
stock front anti-roll bar (sway bar), 26 mm - 14.375 lbs
Cosworth front ARB, 28.5 mm - 18.125
anti-roll bar to chassis bracket and stock rubber bushing - 0.75 lbs
track control arm with stock bushings - 4.75 lbs
chassis cross brace (connects lower ARB to chassis bolt holes) - 2 lbs
stock semi-trailing arm (STA), no bearing carrier - 20.5 lbs
Intercoolers:
Engine:
Driveline:
Electrical:
Interior parts:
Suspension parts:
www.mc2racing.com
www.mc2racing.com
Rear hatch (complete) 65 lbs
Sheet metal surrounding hatch including rear panel ~30 lbs
All 4 rear side windows w/ gaskets 16 lbs (4 lb ea)
Sunroof 12 lbs
Sunroof assembly including tray, sliders, etc ~18 lbs
All tar mats ~30 lbs (the stuff applied directly to the body)
I've got a bunch more stuff removed at this point - enough to fill a projection TV box - a pound here, a pound there, pretty soon you've removed half a ton!
Weight is the enemy - believe it!
Sunroof 12 lbs
Rear Drums 12.5lbs ea
R/ backing plate 9.5lbs ea with the shoes, Wheel Cyl, hardware.
Tbird R/calipers 9.0lbs ea
Tbird rear dics 11.5lbs ea
The brackets 2.0lbs ea
Scorpio R/calipers 6.0lbs ea
Scorpio R/disc 7.0lbs ea
the brackets 1.25lbs ea
wilwood R/hand brake calipers 3.5lbs ea
Alum hat solid rotors 12.5in 5.0lbs ea
Wilwood weight are from there web page.
Ben
Ben
Thanks Chris!
Not as much as I thought, but if I can save 20-30 lbs I might try to adapt a race weight fiberglass hood from another car (like an early fox body Mustang). USBody.com currently (as of 08/2010) has a number of fiberglass hoods on sale for $100 each (no shipping available), and I can drive up and pick it up easily enough. Now I just need to figure out what might make the best donor.anglin wrote:North American-spec XR4Ti hood, without sound deadening liner, with emissions control sticker holder - 34.5 lbs
Re: The Official "What Does it Weigh" Thread
And now the Euro Sierra hood weight has been updated.
www.mc2racing.com
www.mc2racing.com
I'm not going to have any weight numbers for the stuff I took off my XR. Things I've found over the years but if you haven't taken off your XR yet, you maybe surprised.
1. gas tank plastic cover
2. gas tank diff. shield
3. go to the 85 power booster from the 89 booster
4. intake manifold that has been ported by bo-port (and you take off the little extra tabs)
5. 89 interior is light then the 85's 7.5 lbs
6. partial tray 11.5 lbs
7. dog bone bell housing, direct pull bell housing. DBB housing is 3.25 lbs lighter
8. aluminum SVO head 33 lbs lighter then stock steel head
9. Shorai LFX lithium battery 6.5 lbs
10.
So my not sure about the whole T9 T5 thing but I just weighed the T5 I have and 82.5 lbs W/bell housing, fork, stock shifter.
Ben
10.
Ben
