Themal limiting fuse - Blower Only Works on High Setting, XR
Phils85ti
Post by Phils85ti » Sun Apr 30, 2006 10:13 pm
thanks for the help everyone and the shack part # ...ofcourse i broke my module trying to get the darn fuse out so im getting another module. thanks again for all the help !!!
89 Red XR,
mods- Probe FMIC, hood scoop, LA2, Big Vam, 2.5 Exh. CAI, pillar mounted boost & a/f gauges, MBC @ 15, dual-wing hatch, aftrmkt. Trans. cooler,tinted windows, mesh grille insert
" Second place is just the first loser "
Phil
LITTELHAWK
Re: Themal limiting fuse - Blower Only Works on High Setting, XR
Post by LITTELHAWK » Sat Jul 21, 2018 1:04 am
With the decline of Radioshack, I'm looking for a different model for the fuse. It looks like this one from Micro Center will work but I wanted to make sure, and others on here may want to know in the future as well.
http://www.microcenter.com/product/4223 ... off_-_Fuse
(Part Number NTE8125 at Micro Center if the link doesn't work.)
'85 Mineral Blue & '87 White Barn Find parked in '92
Post by Ed Lijewski » Sat Jul 21, 2018 7:06 am
I've used that one from Micro Center. It has lower max surge and operating temps, than selections available on the internet, but its working. Tip: slways start the blower and run it on high first for a while to overcome any initial resistance at the bearings.
I also ordered a packet of higher temps Chinese thermal fuses and have them in reserve. I had earlier removed the blower and lubricated bearings and it spun very nicely, but over time the fuse blew again. It's simpler to replace the fuse than to R&R the blower.
DAReese
Post by DAReese » Mon Jul 23, 2018 12:11 pm
Never crossed my mind to run it on high first. The reason does make sense though. I can't imagine it would hurt.
