front brakes
- mangostick
front brakes
hey all.. I figured I would toss this one out there.. does anyone know if the cossie front brakes mount the same as the xr4ti? I know the knuckles are different.. but do the brakes mount the same? .. tis the question. TIA!
where'd I put that damned hammer??
Shawn Mangan
Shawn Mangan
Re: front brakes
The ears are the same 3.4' spacing but beefier and they're threaded for M12 x 1.5.mangostick wrote:hey all.. I figured I would toss this one out there.. does anyone know if the cossie front brakes mount the same as the xr4ti? I know the knuckles are different.. but do the brakes mount the same? .. tis the question. TIA!
Xratties have the caliper bracket threaded, so you could say they din't bolt up the same.
Hat is deeper on Cossies.
My alloy hat is made to work on both the Xratty and Sapphire knuckles by being about 1.5mm off from cenyterline on the one and 1.5mm offset the other way on the other, but that varies depending on the knuckle, sometimes it's less.
John Vanlandingham
JVAB Imports
Seattle, WA, USA
JVAB Imports
Seattle, WA, USA
- mangostick
So definitely not directly "swap-able" without swaping over the knuckles as well? ... hmm. Thanks for the info John, Much Appreciated! I had my eye on your brake setup too.. whats the ballpark price on a front and rear kit? (all parts included to bolt on/bleed and stop happy) I'm pricing out brake solutions to match the amount of "go" I now have under the hood.
Already have the pbr's and svt contour rotors up front.. still stock out back.. I want this thing to stop hard enough to give me acid reflux. If my 07 corolla can do that.. my built xr should be able to as well.
Shawn Mangan
Shawn Mangan
First guy using them said "It feels like I can do "stoppies"mangostick wrote:Just run a M12 x 1.75 tap thru the Xratty mounting ears and throw the things on.So definitely not directly "swap-able" without swaping over the knuckles as well? ... hmm.
Close enuf to direct swappable.
88 per bell, 100 per disc, something for the 16 bolts and all metal locknuts, something for whatever you choose for pads, mid 160s for the Forged Superlight calipoers, or 195ish for the US Brakes F88 calipers each.Thanks for the info John, Much Appreciated! I had my eye on your brake setup too.. whats the ballpark price on a front and rear kit? (all parts included to bolt on/bleed and stop happy) I'm pricing out brake solutions to match the amount of "go" I now have under the hood.
Hoses TBA thios Saturday
Nailing down the final spec for the rears, likely 11 x 1 with Willwood 4 x 1.24 calipers, and hydraulic handbrakes (loads of fun!!! Really)
John Vanlandingham
JVAB Imports
Seattle, WA, USA
JVAB Imports
Seattle, WA, USA
John,
Do the early XRs need a master cylinder upgrade to run the Wilwood calipers?
After a bummer experience with Superlite IIs on a Saab 900 about 10 years ago I set them aside till now when they finally have calipers this size with pistons between the 4 x 1.34 size and the common 4 x 1.75 like I used on that Saab project.whitelx wrote:John,
The Superlites I use have 4 x 1.62, the US Brakes have 2 x 1.34 and 2x 1.75 and this is within 2% of the sizes Ford and everybody else have used since way back when till now on cars this size and the speeds we actually run at ie under 130 mph.
I haven't used these on any stock car, Grant's is the first car with them working and he's using dual masters, no booster.
It should work OK with early, most certainly well with the later set up, or you could just ditch the servo and OEM master and make your own adjustable pedal box sorta like the outdated ancient stuck in the 80s thing in grey next to Fords own "909" version in black:
Then you can select the master cylinder size easily.
John Vanlandingham
JVAB Imports
Seattle, WA, USA
JVAB Imports
Seattle, WA, USA
- mangostick
I'd like to be able to go to a full manual setup like that.. It seems to be alot of work.. but well worth it in the end. I'll have to give you a call sometime John. I like the simplicity of being able to not rely on engine vac for solid braking. How much modification is needed to swap over to the dual master setup?
Shawn Mangan
Shawn Mangan
If you look at Skye's site, he used to have a pretty good diagram.
My setup from Checkpoint Racing was around $300 and is a bolt in, requiring two new holes drilled, and I welded in a reinforcement plate on the firewall. Figure closer to $350 these days with $#!%^& exchange rates.
I used a K-sport hydraulic handbrake that was $162.50 with master cylinder.
All custom lines, reservoir, etc. If you do hard lines, probably could do for under $200 if AN fittings, less if something else. Then around $75-100 for the soft braided to calipers. I did all stainless braided teflon soft lines and proper bulkhead fittings everywhere and it was about $500.
The rear brake setup I did was around $900-1000. 11X0.84 rotors with 4X1.25 Wilwood NDL rotors and a custom bracket with 7/16-20 threaded inserts. The rotor hat requires the hubs to be turned down a very slight amount, though they still remain about the same diameter as the front hubs.
My whole brake setup was somewhere around $3000, but I had some waste in fittings and lines since I wasn't certain on method. Now I have a spreadsheet with exact part numbers and a diagram for running all soft lines that I am more than happy to share. Need to spend another $50 on an in car adjuster for the bias box still.
- mangostick
Hang on a bit and I'll have another run of 5-6 of the copiesof the Ford parts.mangostick wrote:Cool.. what was the web link to the place that offered the bolt in mc conversion? .. That saves me a lot of fab work/time to be able to buy that part rather than build a rig like that from scratch.
Found a new-to-Xrattiness guy who is just setting up to do sheetmetal, laser cut bending and of course he wants to build a rally car so if'n he's doing one, then why not 6-10
I already have a pile of the basic boxes.
And naturally it'll cost way less than Grant's impulse buy.
John Vanlandingham
JVAB Imports
Seattle, WA, USA
JVAB Imports
Seattle, WA, USA
Re: front brakes
Anyone know the Cossie rotor offset as compared to the Contour SVT rotor that many of us use? Is the offset the same as a stock XR rotor? I was just mocking up a Scorpio front knuckle with a Brembo 4-pot off a Porsche 951 - I need more rotor inset if this is to work.janvanv wrote:Hat is deeper on Cossies.
Hmmm, then again, maybe not... Just thought of another way to possibly make this work.....
