Pics of my cone filter hack job lol
It's not the best but it's a billion times better than the stock box was. I was curious though if anyone thinks that rubber elbow could actually collapse under hard acceleration? The part i don't like is that the filter is actually slipped over the rubber elbow...there's nothing hard in between them, but the clamp does tighten to a stopping point. I went and bought a cheap APC hard plastic 90* bend and tried it out but it wouldn't fit where i have the VAM mounted so i've gotta make another bracket to hold the VAM to use anything else. It's really tight right in front of where the elbow slips over.
Oops sorry about that. I was rearranging pics in my photobucket account and i guess that killed the links.
What i did was take the stock lower tube that snakes up into the filter box and i cut the 90 degree bend out of it and that's what the filter is mounted to. An inner fender mounted filter would be way better but this will do for the time being.
cant fit the filter directly to the VAM?
demonfire wrote:cant fit the filter directly to the VAM?
Well yes and no. The first problem is that the filter has a 3'' outlet and the VAM is something like 2.5'' or so, so i'd have to find the right size reducing coupler to make it fit. Secondly i've gotta make a different bracket to move the VAM back further because the filter won't fit.
While on that topic, does it matter if the VAM is mounted sideways or upside down?
- milehighXR
Or a big VAM...EVIL_XR4 wrote:demonfire wrote:cant fit the filter directly to the VAM?
- milehighXR
- milehighXR
Not that I am aware of. It could cause problems having it mounted sideways(inlet/outlet in the vertical postion). Upside down may not be an issue though. Others would know better than I. It will not fit the stock Merk bracket though.
Yeah i'm gonna make a new bracket, and there's the two holes on the one side that the stock bracket bolts to, but they're on the 'driver's side' of the VAM in its stock orientation...it would be a lot easier to make if i could mount it upside down so they're facing the fender/shock tower. I'm just curious since there's a moving part inside there....i don't know how gravity will effect it if it's flipped over.
The big VAM will too fit in the stock Merk bracket-- I've done it. Just enlarge the hole for the wiring plug upwards, and squeeze that baby in there-- it'll go, with a little bending and patience (I dunno, dinner, a movie, a few drinks back in the garage?). The stock inlet hose will also stretch to fit the large VAM opening also-- warm it up, a little lube... you know.
Well mainly i'm going to make a new bracket so that the VAM sits further back to make extra room up front for the CAI piping. Right now there's only a few inches in front of the VAM inlet to put anything....that's why i had to use that tight little 90 degree bend). If i make a new bracket (big or little VAM either one) to make it sit further back, i won't need such a tight bend and i could either put the filter right on the VAM or make a straighter shot with the piping going to the fender opening.
