Let see pic's of your XR with killer wheels
Ralphs Rapid Transit
Post by Ralphs Rapid Transit » Fri Apr 30, 2010 10:03 pm
Post pictures of your XR with aftermarket wheels you chose for your XR. Don't forget to add tire and wheelsize.
I need help picking out a new set if wheels for my XR. I ordered a set of 16x7.5 and they hit the strut, offset was way off. Back to the drawing board.
Show me what works on your XR
1985 Merkur XR4Ti bought new still have it!
1985 LeBaron 2.2 Turbo K-Car Conv.
1986 Capri 5.0
1994 Viper R/T 10
and 11 other MuscleCars from the 60's & 70's
xrattiracer
Post by xrattiracer » Sat May 01, 2010 12:17 am
theres a huge thread about this on merkursport already, its worth checking out.
I got some 17x7 40ET wheels off craigslist, not sure what manufacturer. they fit just fine on a stock setup.
http://www.flickr.com/photos/29953206@N03/4553324202/
03 VW Golf tdi
05 Yamaha FZ6
Post by Mike McCreight » Sat May 01, 2010 7:59 am
If you like the rims, go with (gulp) spacers. MC2 can supply the ARP studs.
We have an odd offset. Focus rims are usually too high an ofset, RWD too low.
17x7.5 Mullins (Australia) w/205-50 BFG KD (measure out at quite a bit larger than typical 205-50-17) Took a bit of work to get these in. Spring perch and fender lip mods required. These wheels will return with 235 and 215-40s.
TSW Hockenheim R 16x7.5 with 225-45-16. Offset isn't marked on these, they're Sierra specific. No centering rings. They really did their homework, NO issues with a stock suspension car. I'd never seen a 225 up front without mods before.
NiggyMerk
Post by NiggyMerk » Sat May 01, 2010 10:27 am
These are Ford Racing Cobra R's 17x8 cut down to a 21mm offset. Fronts are 225/45s and rears are 245/40s. They all rub a little over big bumps even with fenders rolled. Might go with 215 front and 225 rear next set.
1987 Xr4ti (Rosso Red) - LA3, Big VAM, Cossie exhaust housing,
Cosworth 2wd IC, Turbo back 3" exhaust with Magnaflow muffler,
TC rear disc brakes
Nick
Longitudinal
Post by Longitudinal » Sat May 01, 2010 11:08 am
Mike,
Where did you get the Hock-Rs, and how much did you pay?
xr4ti41028
Post by xr4ti41028 » Sat May 01, 2010 4:12 pm
Longitudinal wrote:Mike,
good luck finding some tsw doesnt make them and they are harder then hell to find been looking for over 3 years now :cry:
Thomas
Graham, washington
lscmark
xr4ti wheels
Post by lscmark » Sat May 01, 2010 9:42 pm
Primax 772 17 x7 with 215/45/17 tires.had to grind about 1/4" from outside edge of front coil spring seats,otherwise,great fit/handling.
Mark
Post by Ralphs Rapid Transit » Sun May 02, 2010 1:31 pm
very nice! Let's see more, Please...
Last edited by Ralphs Rapid Transit on Sun May 02, 2010 8:20 pm, edited 1 time in total.
1986 Capri 5.0
1994 Viper R/T 10
Post by hEaT » Sun May 02, 2010 5:42 pm
BSA 333's, 17x7 +40mm offset with 215/45/17 Dunlop Direzza Z-1 Star Specs. Factory studs, no spacers, coilover conversion in the front.
Joe
1985 Nimbus Grey XR
2017 Ford Focus RS
leesonic
Post by leesonic » Sun May 02, 2010 8:03 pm
Focus wheels are easy, 25mm spacers on the back, 15mm on the front.
Capri 6x13s only fit on the back. Now 7x13s are a different story...
Lee.
1988 XR4Ti red
KingpinCEO
Post by KingpinCEO » Mon May 03, 2010 7:03 pm
235 40-17 in front
275 40-17 in back
same cobra R replica wheels as posted a few posts up.
Post by Ralphs Rapid Transit » Wed May 05, 2010 10:53 pm
All those XR's are ImageSEXY!!!! Keep them coming....
1986 Capri 5.0
1994 Viper R/T 10
Post by Ray » Thu May 06, 2010 7:20 am
Pony wheels painted white in 225/50/16 RT615s
Motegi MR3's 17x7 with 13mm front and 15mm rear spacer (ET was 42mm on these wheels) wrapped in 225/45/17 kumho V710
17x9 ET20 mustang cobra replicas wrapped in 275/40/17 kumho v710
Am looking for a cheap set of 17x8's ET20-30 if anyone has any!
nathankershaw
Post by nathankershaw » Thu May 06, 2010 1:23 pm
What wheels and specs are they on the black one?
They look great!
The stable is empty...
Post by Ralphs Rapid Transit » Thu May 06, 2010 6:23 pm
nathankershaw wrote:Ralphs Rapid Transit
They look great!
The wheel and tire package is. Elbrus IO5 17x7.5 41MM offset, with 205 45-17 up front and 225-45-17 in the rear. Best thing is they don't rub
1986 Capri 5.0
1994 Viper R/T 10
