header and turbo GLOWING
I installed my boost controller today set it to 14psi bc it cuts out above that fot some reason. i get home after a few passes and the header and turbo were glowing red. how bad is that?
- T4EaterJonny
Is your cam timed? If it is overly retarded you will see higher EGT's.
If you go out, drive the car hard and then run right home and pop the hood, the exhaust is going to be glowing. Normal.
You could be getting "noise" that is setting off the KS, thus causing the issue.
Plug gaps could be too big, etc, etc.
I thought stock gap was 0.037"?
