2manytickets
Posts: 185 Joined: Mon Aug 23, 2010 9:26 am
Post
by 2manytickets » Sat Sep 18, 2010 11:22 pm
I really need some help i swapped out my valve cover gasket now i put everything back together and im getting 0 boost. Gauge goes to 0 and stops. I made sure everything was hooked up and vacum lines are good. Any help would be great.
Posts: 14824 Joined: Wed Jan 08, 2003 11:40 pm
Post
by DPDISXR4Ti » Sun Sep 19, 2010 9:24 am
You do realize there's no relation between a valve cover gasket change and boost pressure, yes?
Posts: 3987 Joined: Fri Oct 31, 2003 8:44 pm
Post
by Mike McCreight » Sun Sep 19, 2010 9:55 am
X2
Start by checking to see if your wastegate arm is still connected.
2manytickets
Post
by 2manytickets » Sun Sep 19, 2010 10:25 am
i relizie there is no relation hence the confusion all i know is that it worked before i did it and now it dosnt
2manytickets
Post
by 2manytickets » Sun Sep 19, 2010 10:38 am
wow im retarted i guess turbos work better when the wastegate arm is hooked up is there supposed to be a clip or somthing there
Posts: 1980 Joined: Wed Mar 24, 2010 2:07 am
Post
by Esteban » Sun Sep 19, 2010 1:26 pm
Yes, there should be an e-clip there. Not sure what size though.
Post
by Mike McCreight » Sun Sep 19, 2010 3:41 pm
I knew it...
I argued with those clips for a while, then I figured out how to hit the canister down with the butt of a hammer.
That'll angle the arm up enough that the arm won't fall off when that blessed clip does.
85xr
Posts: 158 Joined: Sat Oct 04, 2008 7:18 am
Post
by 85xr » Sun Sep 19, 2010 5:05 pm
when i bought my DD, the PO had an alligator clip on the accuator rod.
greg
2manytickets
Post
by 2manytickets » Sun Sep 19, 2010 5:07 pm
these damn things are way funner with a turbo anyone know that
