Some pictures are just nail it...
Post by DSPXR4ti »
What I was trying to do is shortening the length and keeping down the amount of turns going from the turbo to the intake runners to keep up the air speed, I guess, it all makes sence to me :roll: .
RatFink
Post by RatFink »
DSPXR4ti wrote:What I was trying to do is shortening the length and keeping down the amount of turns going from the turbo to the intake runners to keep up the air speed, I guess, it all makes sence to me :roll: .
Makes sense to me too. Innovative, nice work!
Daniel Llewellyn
Randy Pobst
I just love this guy:
grve66
Post by grve66 »
very similar to the way I had mine rotated also..
http://www.merkurtech.com/merkurtech/in ... ric005.jpg
http://www.merkurtech.com/merkurtech/in ... ric003.jpg
it made the intercooler tube about 1 1/2 feet shorter..
Post by DSPXR4ti »
Thats the way I have my FMIC because of the SCCA rules, I can't cut holes, or mod the body to put in a FMIC.
The only differents is..I 120ed my upper intake
which saved more intercooler tubing.
What are you doing for an idle air control valve Ben? That's almost identical to how i want to build my upper intake, but i plan on using either the stock TB or a mustang TB.
hEaT wrote:One thing to take into consideration to is if you rotate the compressor side and still use the factory flanged inlet, it's going to be pointing in a weird direction.
There are different ways of dealing with this, but one is to make an adapter which has the effect of rotating that inlet back to the right orientation. Or, buy Richard Thompson's, if he's still making them;
http://www.merkurxr4ti.com/myparts.html
Scroll down, you'll see it.
Post by DSPXR4ti »
Ray wrote:What are you doing for an idle air control valve Ben? That's almost identical to how i want to build my upper intake, but i plan on using either the stock TB or a mustang TB.
Hey Ray,
Throttle body, idle air control, TPS all came from a 99 ford explorer, with the 4.0 V6. The main reason I went this way was because I didn't want to cut/shorten my throttle cable when turning the upper intake. The thing I liked about it was the fact that it's shorter then the 5.0 throttle body, which meant that the turn into the throttle body had a nice radius, not a very sharp 90.
coupelx
Post by coupelx »
Hey Ray,
i really like that throttlebody. its alot shorter than my SC throttlebody. whats the bolt pattern like? it match up to anything else?
1987 Xr4ti
Post by DSPXR4ti »
So I had some jack up upper intakes laying around and cut the base flange & the TB flange. So the bolt pattern I used is the stock XR TB bolts pattern and redrilled the TB to fit, It looks as though it's just like the 5.0 bolt pattern but not sure.
Post by DSPXR4ti »
OK I just looked up the part number and it actually go to a 87-93 5.0 mustang, Sorry about that. If you look under Feabay you can see them look under item #280587243771 for a used one.
Post by anglin »
RatFink wrote:It's the stud and nut under the elbow.
I totally had that one as soon as I saw it. Just didn't see the thread until now. It was probably easy for me to spot because I worked on this model just the other day!
That is a cool picture, BTW.
Post by hEaT »
Anglin, what's the bung in the side for? BPV that close to the turbo?
C-Rock
I got this one
Post by C-Rock »
This looks like a NEW front mount RS 500 Style Intercooler set up, with a 90 degree intake. Set up with a rotated turbo and using a Cosworth turbo housing and the 3 inch down pipe. This looks like it is a total Area 51 project.
C-Rock
RatFink
Post by RatFink »
8)
Daniel Llewellyn
Randy Pobst
Post by anglin »
hEaT wrote:Anglin, what's the bung in the side for? BPV that close to the turbo?
That's what Rapido used it for. Combine the use of this location for the BPV and and 3/4" diameter BPV and you realize how underdesigned Rapido's bypass valve system was. I have a plug in mine. There's also an undrilled bung on the back side that's more properly sized for thermocouple or something.
