Clutch pedal bushings???
Couldn't find another thread about this, but are there replacement bushing available for the clutch pedal?
Re: Clutch pedal bushings???
Maybe blugg have them, not sure but ask him, he got a lot of parts, even many not listed on the web page so give him a call or send an e-mail, here is the web site (but is better if you call or e-mail):
http://www.merkurmidwest.com/index.html
If not already available through a vendor I can machine a run of them out of aluminum or Delrin.
Power is nothing without control.
To the best of my knowledge, no, these are not available from anyone. I can't recall ever seeing it available as a factory part. I like the idea of someone producing them in delrin or other suitable material.nzwinrz wrote:are there replacement bushing available for the clutch pedal?
I had been pondering the same thing, to get my machinist to do some. Have you got a good one to work from, or pedal assembly? How much do you think it would cost?
Glenn
Glenn
Rob'Z wrote:If not already available through a vendor I can machine a run of them out of aluminum or Delrin.
I'm having the Ford dealer send over some for a '89 Fox body, to compare, possibly the same. Keep ya posted..
UPDATE no beano...to thin and longer..
I did find them with quadrant from OPMD
I have a 5-speed XR but haven't pulled it apart before. If someone can get me accurate measurements of a good stock piece(s) I can make some. Guessing $15-20 shipped for a pair.
Rob
Rob
I took the two out of my auto brake pedal, they appear good, lot tighter than the 5speed, same ones. I'll get my calipers and measure them, and the shaft & pedal
A diagram or some pictures showing their orientation would be great as well.
Rob
Rob
Got this with my home unit, can get decimal reading once I go back to work tomorrow
Shaft diameter..
Outer Diameter..
Inner Diameter..
Shoulder Thickness..
Total thickness..
Locating tab..Could probably do without
Shaft diameter..
Outer Diameter..
Inner Diameter..
Total thickness..
How bout I send you, a pedal(my old brake), shaft, mount and 2 bushings. You can use for development.
Once you have, how long to make?
Without the tab I can EASILY make thos in the CNC lathe. With the tab I'm probably not interested in making them.
PM me for shipping address if you want to send parts, probably not necessary with the more accurate dimensions.
Rob
Rob
I don't believe the tab is necessary, I don't see the need to hold them from rotating.
Could they be done in Brass?
That was my thought as well. And machined as a "minor" interference fit, it shouldn't rotate any way.nzwinrz wrote:I don't believe the tab is necessary, I don't see the need to hold them from rotating.
The 2 most critical points are the shaft od is .6275 and id of pedal arm .745
I measured the nylon bushing installed, does compress some from pics. ID tightens to .632-.634
