Just got it today
Spaldino
Re: Just got it today
Post by Spaldino »
Where in Michigan are you located? I'm in Kalamazoo and like to go to local car get-togethers/meets. cars and coffee once a month and usually a weekly little thing. it'd be cool to roll up 3 Merkurs deep at least once if I can get Brian to continue to come.
abomb1982
Post by abomb1982 »
Charlotte MI, just south of lansing.
abomb1982
Post by abomb1982 »
I would like to know If these are the right parts to do the ranger cam upgrade
http://www.ebay.com/itm/FORD-2-3-MUSTAN ... pg&vxp=mtr
and
http://www.ebay.com/itm/83-87-Ford-Rang ... kT&vxp=mtr
abomb1982
Post by abomb1982 »
OK upon doing soooooo much research I am thinking the saab radiator with the merkur depot intercooler. Please PPLLEEAASSE tell me if this is a GOOD choice???????????????????!!!!!!!!!!!!!!!! PLEASE!!!!!!!!!!
NiggyMerk
Post by NiggyMerk »
Order a 2wd cosworth intercooler from the uk if you can find a good one.
I got one for $140 shipped. I could not get my Merkurdepot one to work with my setup.
1987 Xr4ti (Rosso Red) - LA3, Big VAM, Cossie exhaust housing,
Cosworth 2wd IC, Turbo back 3" exhaust with Magnaflow muffler,
TC rear disc brakes
Nick
abomb1982
Post by abomb1982 »
Can I keep my a/c with the 2wd cossie intercooler?
abomb1982
Post by abomb1982 »
one more thing why didn't the merkur depot fit?
In XS 7
Post by In XS 7 »
It should fit, I only have the shorty radiator from Merkurdepot and it fits like a glove, I am running an NPR big intercooler and it fits just perfect. I never here of nobody saying that the Merkurdepot combo do not fit. Are you using the shorty radiator? Have your car been in a front accident and maybe have a bend on the front?
:cheers
NiggyMerk
Post by NiggyMerk »
It did physically fit, I just wasn't happy with the performance.
Although many others have used it with success.
TC rear disc brakes
Nick
In XS 7
Post by In XS 7 »
NiggyMerk wrote:It did physically fit, I just wasn't happy with the performance.
I wasn't answer to your post sorry for the confusion, I was answering to abomb1982 he ask: "One more thing, why didn't the merkur depot fit?" :cheers
abomb1982
Post by abomb1982 »
does the 2wd cossie out perform the merkur depot?
abomb1982
Post by abomb1982 »
So pretty excited, my front brake adapters just showed up. I should have some good pic coming up :D
also ordered a saab 900 rad and the 2wd cossie intercooler :headbang
are there any threads out there about the hoses and part #s to use for the rad?
another thing what are people using off the turbo into the intercooler? I was thinking of cutting the oem pipe down and putting a 90* silicon hose on it, but I have seen some people that have a metal pipe with a smooth bend right off the turbo. Are they buying those or making them?
abomb1982 wrote:So pretty excited, my front brake adapters just showed up. I should have some good pic coming up :D
Those are options, as well as getting a compressor housing from one of the other Turbo Fords (or the aftermarket0 which has a straight hose connection, and no flange.
abomb1982
Post by abomb1982 »
I was looking at intercooler pipping this morning and came across something I thought was a great way to do it. Has anyone else tried this? And does this mean intercoolers are non directional?
Most are essentially non-directional, as long as the inlets/outlets are the same size. An example of one commonly used "backwards" is the Porsche 944T IC.
Interestingly, this "crossover" config was used by Andy Rouse, as well as by our own Randy Schilz, IIRC. There's a little extra length to the pipes, but the bends are less severe... and no more length than a lot of IC setups use. It's also pretty easy to fab up in most situations.
