Saab 9000 Heater Core
I've seen this mentioned a few times in the past as a possible replacement, but has anyone actually used one of these? It appears there are two slightly different versions, part number 46 13 881 for a 1986-1991 9000, and 50 46 362 for a 1992-98. The early cars used a quick-disconnect system on their heater cores and apparently that made them prone to failure, hence the revision starting in 1992. Indeed it's the '92+ version we'd want, which I think is all that's sold today (more on that later).
The only reason to go this route is because you can get an all-Aluminum unit, inclusive of end-tanks and nipples. Available new for the (sit down first), bargain price of $319.99
https://www.eeuroparts.com/Parts/5206/H ... swodG-EOHg
You can find lots of replacements available with plastic end-tanks, but I have no interest in that. You should just go with a stock replacement from one of our sponsors and not have to worry about any custom fitment issues.
If you're junkyard shopping, it's possible that you might come across an all-AL version. In fact, you're probably more likely to come across one in an early car, as many of the original will have leaked and been replaced with the later version (a retro-fit kit is sold to fit the later one in an early 9000).
I now have one of the all-AL ones, part# 50 46 362 barely legible. I plan on installing it soon - just drained my coolant a couple days ago when removing the head.
I'll post details in this thread, but if someone wants to beat me to it, feel free.
Re: Saab 9000 Heater Core
Man, talking about 9000 heater cores really takes me back... to all the leaky 9000 heater cores I used to have to deal with.
What year was your car?thesameguy wrote:Man, talking about 9000 heater cores really takes me back... to all the leaky 9000 heater cores I used to have to deal with.
86, 87, 88, 88, 89, 91, 94, 96.
Did you ever need to replace the cores in the '94 or '96? Those would have had the "new & improved" part.thesameguy wrote:86, 87, 88, 88, 89, 91, 94, 96.
I looked at this core, but the hose connections seemed a little too short.
I ended up adapting a Toyota core, as I suspect you recall. Saves at least
a couple hundred dollars if someone's willing to do some cutting and
soldering.
soldering.
Stock heater core I took out of my care had plastic end tanks........
Stock radiator in my car has plastic end tanks.......
Replacement heater core I put in my car for $70 has plastic end tanks.......
Don't see the need to reinvent the wheel.
So yesterday I thought I'd give it a go at fitting the all-AL Saab 9000 heater core. I'm thinking this is going to be much more involved than I thought, as it would involve re-fabricating the heater box to accommodate the larger core. It's not entirely impossible, but probably more effort than is worthwhile.
Semi-related... Any thoughts on whether the black plastic end-tanks are better/stronger than the tan ones? I think the black plastic ones came later, yes? What material are the replacement tanks made from?
Pic showing a 1986-dated original core vs. 1995 Saab 9000.
If after 30+ years your current heater core starts leaking/gets plugged, why not to buy new one for and not have to worry about it in your life time again?
Shameless plug......
http://www.ebay.com/itm/NEW-Merkur-Scor ... 1649512636?
$72.50 shipped for the forum members or $65 if picked up in Carlisle 2 wks from now
Text 75seven-five35-558one for the quickest answer.......
But what if I plan to live beyond 85????ford.scorpio wrote:If after 30+ years your current heater core starts leaking/gets plugged, why not to buy new one for and not have to worry about it in your life time again?
Despite my disdain for plastic end-tank heater cores, replacing with a stock core is increasingly looking like the best solution overall. Perhaps they even made some improvements in the later units and they don't have such tiny passages that become easily clogged? That was my other reason for wanting to fit the Saab 9000 core.
$72 seems like a small price to pay for a do it once and be done with it item.
Well, had the 9000 core worked more easily, it would have been a "done once and better" solution. That was my reason for considering it.DAReese wrote:$72 seems like a small price to pay for a do it once and be done with it item.
- merkurdriver
Sneak peek...
Like the Saab 9000 one, but about a third of the price.
Also direct bolt in to any XR / Scorpio.
Better hurry up Mike, I'm starting to actually get this car together and don't want to rip out the dash again. Looks like a custom piece like your radiators. I'm happy you're having this done.
- merkurdriver
You are correct...and...they're done. Tricky to get them right, but I'm happy with the results.
www.merkurdepot.com -> NEW PARTS XR4Ti
