How many Scorpios are still on the road today?
As I recall they imported a little over 20k.
How many do you think are still on the road today? I'm not counting the ones overseas...
Re: How many Scorpios are still on the road today?
Answer may be coming soon.
- andyofcolumbusmerkur
A hundred and twelve?
Hopefully, this spring will there will be one more.
- merkurdriver
Someone had a list of registered Merkurs from 2017. Cars with current registrations and plates -- "on the road" and there were about 100 1988 models and 100 1989 models. I'm sure the list of parked/expired registration/projects/out in a field in W.VA would at least double that number.
Nate Howard probably has that many in his barn.merkurdriver wrote: ↑Sat Feb 02, 2019 4:56 pmSomeone had a list of registered Merkurs from 2017. Cars with current registrations and plates -- "on the road" and there were about 100 1988 models and 100 1989 models. I'm sure the list of parked/expired registration/projects/out in a field in W.VA would at least double that number.
Did Nate finish the Sierra Cosworth total restoration project? The one Mike used to have?
- merkurdriver
YES.andyofcolumbusmerkur wrote: ↑Sat Feb 16, 2019 9:18 amDid Nate finish the Sierra Cosworth total restoration project? The one Mike used to have?
https://wheelwell.com/nate-howard/1x45/ ... rkur-xr4ti
More Scorpios than I expected.
